Tubes & tables
I’ve been playing more vinyl now that the weather has gotten colder and I found a tube phono preamp kit that I bought when the kids were little. It’s a Hagerman Cornet v-1, running two 12ax7s, a 12au7 and a 5y3. I never finished it because my wife & I both got laid off in 2002 and I couldn’t afford the power transformer at the time. I had stashed it in the back of some shelves in the kid’s gaming room 20 years ago. I found it on Sunday while looking for some of my old albums. I scavenged a power transformer that’s close enough to get it working. The B+ was a little low but substituting a 5ar4 for the 5y3 brought it up within reason. This thing is dead silent even without a case and running crappy old tubes. I swapped in some Tele smooth plates and a 12bh7 and it sounds great.
I’ve been staying up too late listening and it’s hard to shut it down and go to bed.
BilletSteve_Leekenrhodes6thplanetugly_wooferPWRRYDKornbreadTurn2tajanes4thtryand 2 others.
  • Wow, expensive little bugger! Tubes FTW!
  • I think the board was very reasonable and the parts didn't amount to much, minus the transformer. The newer versions use a 9v wallwart and an on-board voltage boost converter. He's selling the previous v-3 version of the bare board for $80.
    I realized last night that the National tube you can see in the photo was actually a 12AT7. It was in the wrong storage box and I just grabbed two junk tubes that were supposed to be 12AX7s. I'm a little surprised this thing still sounded really good.
    Steve_Lee6thplanet4thtry
  • Looks like an all tube preamp from input to output, including power supply. Cool. Have you tried it with your rebuilt Dynaco ST-70 for a complete tube listening experience from cartridge to speaker?
  • edited December 2024
    I really like it Tom! The only thing that would make it cooler is if it was 100% point to point wired with a turret board lol ;)
    It's just the phono stage, so no additional gain or volume control. I would have to rebuild the 6J1 to get that running, but I have an SRPP 6DJ8 linestage that would work. I think I have a bad tube in that ST-70. I'll have to put them on the tester before firing it up again. I'm hoping it's the 12BH7 and not a power tube or even worse, one of the Amperex 12AU7s.
    If someone would get off their butt and put the u-tracer together they could test a few tubes for everyone. :3
  • edited January 2025
    I picked up this old Thorens TD-125 yesterday. The asking price was too good to pass up. I had read these were heavy tables, but I was a bit shocked when I picked it up for the first time. It's closing in on 40lbs with the arm and will need some work to get it looking presentable. But after a quick cleaning and some oil in the bearing, it's running smooth & quiet even after sitting idle for 25 years. The arm is an SME 3009 Mk2 and those go for far more than I paid for the whole kit. It has some minor issues, but nothing that can't be resolved and the parts I need to replace are still available for these. I will probably swap that for the Acos Lustre arm you see over on the right side. That arm is a tank and no tools are needed to make adjustments with that arm.
    KornbreadtrawPWRRYDugly_wooferjr@macSteve_LeekenrhodesEggguytajanesBilletand 2 others.
  • Outstanding find!!!
