I'm a hopeless Luddite and can't bring myself to buy a MiniDSP because I listen to so much vinyl. This isn't a rational decision on my part; I'd just like to get the analog portion of my system as close to optimal as I can before I start adding digital correction. One thing I'd really like to try is an open baffle in the style of Martin J King:
http://www.quarter-wave.com/The crossover components get very pricey with this kind of setup (low pass around 250hz) though and I typically use tube amplification, so power is a premium.  I've been toying with the idea of building an active line level filter and using multiple amps to handle high and low frequencies. Something along the lines of Linkwitz:
http://www.linkwitzlab.com/filters.htmIf just using a full-range driver crossed over around 200-300hz to a large woofer (probably h-frame), it looks to me like the filter wouldn't be too terribly complicated. Has anyone here experimented with this?  I would like to start with an opamp active device, but if it works well I might end up completely losing my mind and building a tube filter.
When I was building my own from scratch I found the "Active Filter Cookbook" by Don Lancaster to be a great reference. I've also used board kits from Marchand which I thought were quite nice. http://www.marchandelec.com/xm1.html There are also active filter calculators on line. http://http//www.analog.com/designtools/en/filterwizard/
Got a new phono design and a power amp that I want to finish first (both hybrid ss+tube, what have I become?), but I think the speaker setup will become the bottleneck before too long.
