Slit cones
  • dont want that
  • When I practiced on a PRV driver, the cutting was easy, but I found the glue I used worked very well. I used Permatex Black Silicone because it's black, and swabbed on the backside of the cone to where it filled the slit. Then I used a tissue or napkin to remove the excess from the front.
  • edited August 2024
    I wonder if ribbed cones would react differently to this treatment.
  • @Eggguy said:
    Or steel wool. This will be an excellent opportunity to get rid of some cheap ass drivers on the shelf
    Steel wool and speaker magnets are a bad combination.
    rjj45Analogkid455
  • I thought the same thing! Asking for trouble....
  • One of my fire Marshall buddies showed us a trick where you take unfolded steel wool put it in a container with a D cell battery and shake...
  • Do they make Nichrome wool ?
    Does anyone really have much experience using the pm180 unmodified?
