OC25SC65 or ???
I've got a project where I'd like to rear mount a tweeter in a hardwood baffle. The opening will be a 45 degree chamfer about 1/4 inch deep. I'll probably cross in the 5-6K range. The kicker is I need at least 90 dB at 2.83v. This would be an all Peerless project if I go with the OC25SC65.
I'm not that thrilled with the 3rd order distortion compared with other tweeters https://hificompass.com/en/speakers/measurements/vifa/vifa-oc25sc65-04
Any other ideas? Not a lot of space to hide a big flange or chamber in a 4 inch baffle width. I've already done a ton of projects with the ND20FB so that's off the table. I can't recall if the small AMTs have the same distortion profiles. The original tweeter was the Beston RT003C without the face plate until Craig dumped on it. :angry:
  • Solen has the Airborne 4001 which has a very good distortion profile.
    https://solen.ca/en/products/rt-4001
    Other than that one, I have used the small flange XT25 and liked it a lot
    Wolf
  • edited January 2024
    Peerless XT25SC40-04 has NO flange and is 91db.
    EDIT: I have an extra pair of these. I'm not sure if there are distortion measurements out there, but I can take some if you want me too.
  • TW030WA03/04 is an option. 4 ohm models, so sensitivity is there.
    Are the lavoce ones any good? Such as TN131.00, TN100.70
  • Wavecor TW013WA01 is a cute little tweeter. I could measure distortion if your interested.
  • XT25 or DX25 BG with the faceplate removed and rear mounted to the baffle with the adapter for the WG 148 waveguide?
  • Good options here. Thank you. The aspirational choice is the TW030WA03/04, looks like the XT25 variants would be close on the sensitivity and the TW013 a little to low. I like the AMT idea. I'd really need to keep the Airborne x-o high. I'm trying to decide if the rectangular opening fits with the design.
    I used the TN131.00 in the speakers I had at InDIYana and SDC with the DIY sliced SB16PFCR-8s. I liked them quite a bit but they aren't necessarily better than the other ones being discussed.
  • Ended up buying the TW030WA03. nice sale and great exchange rate :)
    I can’t find that model on Wavecor website.
    It's an "OEM only" model, not sure why Solen as some stock of them to be honest.
    http://www.wavecor.com/Navigation/oem_drivers.html
