Radiation Pattern of Oval -vs- Round Speaker Driver . . .
edited November 2023 in Related
Are there differences between them (subject) for widest radiation/dispersion?
  • edited November 2023
    Oval driver, oval radiation pattern. Shortest dimension of oval will be similar to round driver of same dimension. Same for longest dimension.
  • Thanks, dcibel.
    So, if I just happened to use a 6X9 triaxial as a MT and oriented it with the long side vertical, it would reduce or eliminate floor and ceiling reflections while retaining the wider dispersion of a 6" driver on the horizontal axis, I gather.
    Cover it with cloth and no-one is the wiser (and PEQ it to perfection crossed to a sub . . .).
  • Those first reflections occur at frequencies where the difference between 6" or 9" isn't going to make a lick of difference.
  • Even if Barbie told Ken he could build a large Home Theater system for their doll house?
