Closed back midrange
Can anyone give me your thoughts about the inexpensive closed back mids at PE?
  • The GRS version with the mesh grill is pretty good. I've used it several times, always surprises me with it's performance.
  • Thank you. I thought that was the one I used before.
    If memory serves, I've used it three times to date. It is my go to for cheap 3-way designs due to its cost/performance ratio. You can spend a lot more for a lot less.
