Sooooo... after much bargain hunting, I now have the drivers (or I will, when the woofers ship) for an old-timey 8" based 3-way.
Woofer: MCM Audio Select 55-1240. I picked this one because it has advertised parameters that indicate it will work in a true "acoustic suspension" alignment, has a groovy old-timey clear poly cone (looking at you, 80's Infinity), and is obviously 8" in diameter. It also has a little more throw than typical 8" woofers in this price range. Not a lot of choices for drivers that look old fashioned out there, these days. I considered using a pair of Dayton Audio 8" Classics - but they have weird parameters. They will not dig at all deep in a sealed alignment, and going vented violates the spirit of the project - plus they require a dorm fridge for an enclosure. They look right - but, come on...
Midrange: Foster 095M1301. 1-1/2" dome, non-chambered mid. Big rectangular faceplate. Voice coil terminated in a visible manner (wires stick out). Beautiful old school midrange with 800 Hz FS. Found them on Fleabay pretty cheap:
http://www.ebay.com/itm/231268049005?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:ITOther than the guy using a HiVi graph (lol), pretty legit. Cheap, too.
Tweeter: (high probability anyways, unless some other beauty of an old-timey looking tweeter comes my way) Silver Flute (distributed my MCM, NLA, 53-1060) 3/4" dome. Square faceplate. Fits the "look" I am going for.
I hope the mids are more or less linear on-axis to at least 4.5K...
Stay tuned.
Never mind, just found these. More better for this build.
Look what else the guy selling the mids has... wish I had seen them earlier!
I also have some L-pads, those might be fun to mount on the front panel.
Something like this is what I am thinking...
Any interest in a retro-themed event? No contests, nothing like that - just build something that looks like it was designed prior to, say... 1990?
Man, the look takea me back.
Going to get them doing the dance of our people and measure soon.
I need to scour local thrift shoppes and goodwills once I spec out a cab. It would be cool to sure-up and retrofit an old cab with these.
I am going to use my quad with the 3/4" MCM paper tweet. Thinking of what to flank it with. I should start a new thread, sorry for the parallel, just excited for the 55-1240s.
A retro-themed event would be awesome!
Only if it is a series xo.
If I come across a value I need, I will reach out.
Tweeter flange is thicker than the midrange flange, so will require some thought on how I want to deal with that. Otherwise, next step is building some cabinets.
I really like the 80's look the poly woofer offered, but it is too high Q for where these are going to end up, which is on the wall in my dads shop. He don't need no 1.5 cubic foot boombox up there.
I digress.
What I really dig are those old timey untreated paper cones and foam surrounds. Drivers like the Bose 301 use are absolute eye candy to me sometimes, not too common to find affordable paper cone drivers without that cheap looking "poly" coating on them, though.
Visaton sells an 8" untreated paper cone, foam surround driver - but at the price point ($30) I can do better performance wise - it is only a couple bucks less than the 8" KB from MCM, that is ridiculous IMNSHO.
I continue in my quest.
Actually, the 8" KB would be just fine, the larger KB have an old timey look to them.
No promise they will be acceptable... Hope they are!
Fs 39 Hz, Qts .5569, Qes .7619, Qms 2.053, Le .5979 mH, Vas 1.38 cu. ft.
And a pair of MCM 55-1455
One coil connected Fs 39 Hz, Qts .7241, Qes .9211, Qms 3.386, Le .5583 mH, Vas 1.3 cu. ft.
Two coils parallel Qes measured .4854. Coils in series Qes measured .4616.
Not sure if the small difference is a WT3 anomaly or if it is real.
The DC200 measured different than specs. I had Zaph do it a few years ago.
Qts. .58, Fs 35, Vas 35 ltrs. if I remember correctly. Not sure if new stock would be the same or not.
