How does this look?
  • The new phone takes quality pics.
  • Very good!
  • Looks like your mashing that tweeter into your desk with a small midwoofer. :p
  • Those frames/cones have a large OD to cone SD ratio. Similar to the Dayton RS series and HiVi yellow woofers. What are those woofers again?
  • Maybe something like this?
  • Hmmmm
  • Do any of the tweeter flanges have the same mounting dimensions?
  • Looks like it should take more than four mounting doohickies to keep it secured. It could just be a trick of the light, but the woof seems substantial.
    I'll check.
  • No, none of the options use the same cutout.
  • hifisiderjj45
  • How about this?
    hifiside6thplanetEd_PerkinstajanesSteve_Leekenrhodesugly_wooferrjj45squamishdrocTurn2and 2 others.
  • Cut and glued cabs for the 4" today. Driver cutouts tomorrow.
  • I may be in the minority, but I've always liked the look of dished cones like that. I always wondered if that would make for a more rigid moving structure without adding much weight when compared to a conventional dust cap.
    jr@macrjj45Steve_Lee4thtry
  • edited June 2023
    I like the look of inverted caps too. Looks more sleek IMO. Though, I figured it could potentially bump the average acoustic center slightly farther back compared to a convex cap.
  • The last setup looks good 👍
  • I'll build both, then.
    squamishdroc
  • Just ordered another pair of the tweeters.
  • edited June 2023
    6.5 inch:
    4 inch:
    Also a 5 Inch:
    ugly_wooferhifisideSteve_Lee4thtry
  • ...all models done with added series resistance of 0.5 ohms.
  • 4thtrykenrhodesugly_woofer6thplanet
  • At the very real risk of not being able to cross low enough to ideally mate with a aluminum cone mid, I have decided on the little AMT.
  • I should add the decision was driven by the fact I can buy forstner bits in both sizes to flush mount them. Strange, but true.
    kenrhodeshifisidejhollander
  • I chickened out on the AMT, I have something in mind for them, though.
    3-way
    2-way
    Nicholas_23hifisideugly_woofer6thplanettajanesSteve_Leesquamishdroc4thtry
  • Yes I dented the cone a bit on the 4" sample, dammit.
  • That three way looks sweet.
    Steve_Leejr@mac
    I'm looking forward to hearing how it turns out. Nice drivers.
