USB Audio interfaces and DACs for sale
edited April 2023 in Classifieds
I have several USB audio interfaces I would like to sell. I can ship (to USA only) or bring to InDIYana if you will be there.
All are in excellent condition and work perfectly. Potential uses include as a DAC or as a measurement interface. I used some of these as part of a PC-based DSP crossover. Please PM me if interested.
Musical Fidelity V-DAC ii SOLD
Nice sounding stereo DAC with SPDIF coax and toslink, and USB, inputs.
https://www.stereophile.com/content/musical-fidelity-v-dac-ii-da-processor
Topping E30 DAC NIB SOLD
Great sounding DAC with remote control.
https://www.amazon.com/TOPPING-E30-Hi-Res-AK4493-Decoder/dp/B0868J7NRV
Presonus Audiobox 1818vsl $120 each BOTH NOW SOLD!
8 mic/line inputs, 8 analog outputs, SPDIF/ADAT
https://www.presonus.com/products/audiobox-1818VSL
Focusrite Scarlett 6i6 $80 each (two one available)
4 analog inputs, SPDIF in, 4 analog outputs, SPDIF out
https://www.sweetwater.com/store/detail/Scarlet6i6G2--focusrite-scarlett-6i6-usb-audio-interface
Focusrite Scarlett Solo $20 each (two available) BOTH SOLD!
analog 2-in,2-out, bus powered
https://focusrite.com/en/audio-interface/scarlett/scarlett-solo
Asus Xonar U7 SOLD!
8 analog outputs, 2 inputs, SPDIF out. Bus Powered. Good S/N ratio. Was one of the first affordable, good performing, USB multichannel DACs.
https://www.asus.com/us/motherboards-components/sound-cards/hi-fi/xonar_u7/
Behringer UCA202 FREE! (two available) BOTH SOLD!
analog: 2-in, 2-out plus SPDIF toslink out. Bus powered.
https://www.behringer.com/product.html?modelCode=P0484
  • I'll take both Solos please.
  • I'll bite for 1 Audiobox shipped to TX.
  • @kenrhodes Do you need them shipped?
    @Silver1omo Sounds good I will get back to you on the shipping soon.
  • Indiana would be fine or if you find yourself coming to the Grand Rapids area we could meet up.
  • Does the Topping have a remote?
  • edited April 2023
    Yes! It can adjust playback volume and IIRC select which input is active. Pretty handy.
  • Any of these will work with Pi and your code for active speakers?
  • edited April 2023
    All of them, I believe. Did you have any one in particular in mind?
  • edited April 2023
    which one would you suggest? for 2 way / 3 way with Pi. I'll PM you
  • Which gen is the Focusrite Scarlett 6i6 and does it work with a pi4/moode? If so, I'm in!
    That is what I want the presonus for. Quick Google fu says it works in Linux, so, Camilla dsp should work.
    It's second Gen. Yes, the whole Scarlett line works well under Linux.
  • Been looking for a dac. I'll take the Musical Fidelity, if you still have it.
    PM sent.
  • Just updated the list in the first post. There are still a couple of units available.
  • Shipped out a couple of units today. There are still two left:
    Focusrite Scarlett 6i6 $80 (would make a great measurements interface)
    Asus Xonar U7 $20 - price reduced!
    See descriptions of these in the first post or online.
  • i'll take the Asus Xonar - this will also work with Pi / Linux for 8 ch DSP?
  • edited April 2023
    Yes
    charlie@CI327:~$ charlie@CI327:~$ aplay -D hw:3,0 --dump-hw-params /dev/zero
    Playing raw data '/dev/zero' : Unsigned 8 bit, Rate 8000 Hz, Mono
    HW Params of device "hw:3,0":
    ACCESS: MMAP_INTERLEAVED RW_INTERLEAVED
    FORMAT: S16_LE S24_3LE
    SUBFORMAT: STD
    SAMPLE_BITS: [16 24]
    FRAME_BITS: [32 192]
    CHANNELS: [2 8]
    RATE: [44100 192000]
    PERIOD_TIME: [125 1000000]
    PERIOD_SIZE: [6 192000]
    PERIOD_BYTES: [64 4608000]
    PERIODS: [2 1024]
    BUFFER_TIME: (62 2000000]
    BUFFER_SIZE: [12 384000]
  • sent you an PM.
  • Asus Xonar U7 is now sold. One Focusrite Scarlett 6i6 is still available at $80...
  • I'll take the 6i6 if it's still available.
    B)
  • SOLD!
    That's everything B)
