I have a set of Audax HM130CO drivers I got at InDIYana a few years ago. Now I see that Charlie is selling another set. I have been wanting to "upgrade" my Tritrix TL speakers for a while now. The HornRESP model looks good with the Audax woofers. My question is are these a good fit in a 2 way speaker? Or are they better used as a mid? Would I be better off with the RS150 instead?
Thanks!
It's a 5.25" driver with limited Xmax, so keep that in mind for your expectations of LF extension. The driver has reasonable performance and good sensitivity for its size. One possiblity is a small 2-way system crossed over at 150Hz to a subwoofer, or as a midrange crossed over a little higher than that. The RS150 lineup might have slightly better distortion performance but I never compared the two directly. The HM130C0 is IMO one of the better drivers from the old Audax lineup and can still hold its own today despite the age of the design.
Answers
Thank you for the reply Charlie. I modeled the Audax and RS150 against the 5" classic used in the TriTrix MTM. They all model exactly to same in the enclosure. As far as power handling/SPL the Audax gain 1db over the classics. While the RS150 gain 4db at double the power.
I am not sure that this matters much as I don't have any complaints with the spl of the Standard Tritrix...
Found this
https://ampslab-spk.com/2017/08/22/audax-hm130c0/
https://ampslab-spk.com/2019/02/04/audax-hm130c0-carbon/
https://ampslab-spk.com/2019/03/12/orion/
https://ampslab-spk.com/2019/06/28/orion2/
https://ampslab-spk.com/2021/02/24/orion-rt13/
Seems he liked it enough to mess around with quite a bit
The HM130C0 is a great driver and built like a tank. I think it looks very cool with an inverted surround and nice carbon fiber cone. It's probably at its best as a midrange and not as a mini-woofer. It has pretty high sensitivity and breakup is very well controlled. Some excerpts from AmpsLab writeup (second link):
Some interesting and insightful comments there but OMFG if I hear another person talk about the "speed" of a driver that they listened to I am going to puke. The transient speed is 100% set by the upper frequency response limit of the driver. That's it! Don't believe me? Just put a lowpass filter on it and see how it "slows down". You can easily measure it. Where is the facepalm emoji when I need it! Also: it's not because of a high Qms either. The Qms of this driver is 3.6! But still "fast"...
OK, I am done hyperventilating now...
BTW there is still one pair available.
I bet it has tight bass.
Fast, high, and tight!
