8" 3-way coming soon
This build will be using the Dayton DSA 8" woofer, that new HiVi 3" dome, and the GRS/Fountek knockoff round faceplate ribbon tweeter.
The woofer models pretty well in 1 cubic foot, tuned to 40Hz. Models done at 20W and 0.5ohm added series resistance. F3/6/10 of 39/34/30.
In this alignment, it does not exceed advertised Xmax until 29Hz, comfortably below most music content. Anechoic SPL at 20W of 100db.
This would be 94db after full baffle step losses. A typical 85db listening level requires just a couple of watts and cone excursion is under control well in to infrasonic territory. This should be a cranker build.
The dome is new to DIY so performance remains to be seen. It isn't exactly cheap, however.
I am going to poke the bear a bit - this will be named "O'Ryan" in honor of my Irish heritage and as a play on words with PE pulling their naming stunt on their 3-way kit.
Anyways, this marks 3 active projects which is enough for the year. I am targeting all sawdust done by end of March and then the process of developing three different crossovers.
This one will definitely be at Iowa along with that SB/Hiq build.
e6ziontajanesSteve_LeeColonel7Silver1omo6thplanetugly_wooferrjj45kenrhodesS7910and 4 others.
«1345
