Is anyone using one of these, Denon HEOS Link Wireless Pre-Amplifier For Multi-Room Audio - Series 2,
for streaming and if so, what are your thoughts? I'm still searching
for a streaming device I can integrate into my system and doesn't cost
more than $350.
Jim
https://www.accessories4less.com/make-a-store/item/yamwxc50ds/yamaha-wxc-50-musiccast-wireless-streaming-preamplifier/1.html
The amp version measured favorably in:
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-yamaha-wxa-50-streaming-amp.7964/
So not a lot of help, I know...
A RPI with a DAC can be very flexible.
Are you streaming with something at the moment?
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-jds-labs-el-dac.4850/
Looks like a great performer.
So, did it work for you?
It's still a work in process. I liked it so much when I first bought it, I bought another for my 2nd system. With Amazon HD Ultra music it allows access to an almost unlimited amount of high quality music. I'm using the Link as a transport connected to DAC's and sound quality is very near my Squeezebox system. That said, the built in DAC in the Link is much, much better than I anticipated but not as good as music off my server with the Squeezebox or through my DAC's.
That said, both suddenly stopped playing music which Denon support thinks is related to my network which I don't agree with since they wouldn't play music from a flash drive plugged directly into the Link. Today, I'm totally uninstalling them, resetting the devices and the the network, then reinstalling software for a fresh start.
Today I'm attacking it and hope to have music playing soon. I'll post the results.
Jim
Not surprised with them looking for a scapegoat. Good luck taking the gremlins out.
I think they have an issue with the software. I'll keep everyone posted how I get along. This is a very nice unit with darn good sound quality. Time will tell.
Jim
I promised a follow up and here it is. I worked with Denon HEOS Link support and after resetting the Link hardware and reattaching them to wireless in different "rooms" they're both playing perfectly. The Link has to be attached on the same wireless channel as the phone/tablet controler is. That rules out using Ethernet connections for me even though I have that capability.
So, the selection of music is enormous and sound quality is really excellent! Amazon HD Ultra is only $12.95 per month if you're a Prime member. That makes it the least expensive high-rez streaming option available that I'm aware of. I am using mine through external DAC's but the built in DAC's sound very good also. I'm able to access any source on my network including my music server and a USB flash drive that can be plugged into the back of the Link if you want. It's not the cheapest solution but it's worth it to me.
HTH,
Highly recommended....
Jim
You should be able to get your wireless and wired network to look like one network. I've done that with my network and while I don't remember how I did it I know it can be done if your equipment lets you. I have a DSL modem running through a Vonage phone box to a Linksys wireless router. I think I disabled DHCP on the Linksys router but I can't be sure because now that it's configured I can't seem to get into it. I did this so my laptop and phone could get to all the printers and computers on the wired side.
Thanks for the heads up Ron. Other than the fact I prefer wired, wireless is working flawlessly so I'll probably proceed with caution.
I always try and use wired whenever possible. It's faster and easier on DHCP devices. Right now I'm really enjoying the huge diversity in available music.
Stay safe!
Jim
It depends on the gear you have and how the device validates it is in the "same network".
Generally speaking, if the wireless AP is the same device as the wired network, all services will be given from the same device (likely a wireless router).
But if you have more than one device it can be complex.
