For example; you have a pair of speakers playing and the central parts of the music are perfectly centered when you're seated in a roughly centralized
spot, but when you stand up and walk over toward one side this "phantom center" effect breaks.
At around 0:14 into this video
there's a simple polarity test using mid-focused noise and flipping phase in/out between the speakers. In-phase, while sitting in the "sweet spot" it sounds nicely centered while the out of phase noise sounds seperated L/R and distant or hollow. However, if I lean a couple feet left or right, then the out of phase signal actually sounds more centered while the in-phase noise sounds a bit more noticeably separate L/R.
Is this normal speaker behavior (the out-of-phase signal ending up sounding more like the in-phase one when outside of the sweet spot)?
What things can a DIY speaker builder do to increase the size of the sweet spot where centered music and effects sound..centered?
If the source is not mastered to that end, it won't happen.
But I'm happy it doesn't seem to be tied to the driver spacing/timing or the crossover.
I'm doubly fortunate that I don't seem to have an issue with the "center" drifting for different frequencies, and I don't think my hearing is noticeably unbalanced L/R. I can only differentiate up to 10K for pinknoise VS fullrange pink and only hear around 14K for sinewave, but I'm not sure how much that affects this.
