Doing an install for a guy at work who wanted to improve the overall quality of his truck's audio.
Budget Max: $1500
Prospective Equipment:
Kenwood DDX396
Fountek FR58EX
Seas L16RN
GRS 10SSW-4 (x2)
Pioneer GM-D9705
I've always liked Kenwood HUs and this one comes with 3way network active in a double din for under $300, seems like a no-brainer.
You guys here convinced me to go with a 2" full range to help with the gap between the A-pillar and lower door and I have these on hand. Great reviews, I've used them in a BT application and they sounded very nice with no network on them, so we'll roll with them unless anyone sees a glaring issue.
Seas L16RN. Great deal and overkill for what's going on here SQ wise. Doors will be sealed and lined with foam.
He isn't worried about lowest octaves so I figured the GRS slim subs would work perfect. (I received them as a secret santa from PETT and used them in my car for a while, should be good) Going under rear seat to spec, .5cubes sealed and stuffed. I was considering a pair of eD 7kv.2's ported but can't get myself to let go of them.....
Honestly the most difficult decision I've been faced with and am still on the fence about, but it should honestly be perfect for this situation, lots of headroom on the top end and low end, which will hopefully leave the mids to be solid on power.
If you guys have any rec's or criticisms let me know.
Stopped to watch the super bowl at about 1715-1730 with a quick pull of the A-pillar tweeter grills to see about fitment of the Fountek 58's......not gonna fit.
Tomorrow I'll run speaker wires and start tearing apart doors and A-pillars and start subwoofer enclosure/amp rack.
Pics to come and trying to figure out the high end.....
Today I finalized the wiring, got the doors treated and sealed, woofers reused the mounting carcasses from the stock woofers, stock tweeters I got wired up for the time being as I wait for the new ones to come in, HU got finalized and installed and amplifier wired up and everything checked for function and learned my way around the HU.
For what it is, this system sounds absolutely amazing. The tweeters are a bit harsh and less than smooth but they don't sound as bad as I was expecting. Those Seas woofers.....ERMAHGERD. They are beautiful and I am jealous I can't use them in my car.
The head unit I chose does 3-way networking and though it doesn't have an infinite number of options for crossover points and other adjustments, there is enough to get it wrangled in, and with the time alignment and gain adjustments at your finger tips instead of needing to go to the amplifier it is real nice for tuning.
I sat in the truck for about 30 min and could have easily stayed in there a while longer listening to what I consider some quality testing tracks including dire straits, pink floyd, regina spektor and a few others. Definitely could have gotten lost in there...I don't know how people just don't truly enjoy and love music.
I am over the moon about how this turned out. Hoping to get the sub-stage completed and in tomorrow before the owner comes over for a listen.
Sorry guys...I'll reconfigure ....
Yeah, the boot was starting to be a pain but then figured out there was some kind of rubber strips in there lining it or something, so jammed that long ph2 through, taped it up and then put some gold bond on it and zip! right through.
So MDT-12's ended up in the A-pillars. I was able to trim down the face plate on opposite sides so it had an "eye" shape, and hot glue it behind the A-pillar tweeter grills. Took some finessing and grinding but made it in there.
GRS 10SSW-4's got put in separate .5 cu ft enclosures fully stuffed with pillow stuffing, downfiring under each side seat and the amplifier in the middle with a removable top panel. They were worth every dollar of the $25 they cost. Fantastic and perfect for the customer's listening preferences. Mated with the L16RN's lots of kick in the mid bass and still hit hard in 90% of rap and electronica music. Only sub 30hz really struggled.
Very clean as far as distortion, so that was good. I could not quite eliminate all the shoutiness with certain female high notes and electric guitar, not sure the reason for that..... tweeters in A-pillars shooting at approx 1/3 location of windshield and woofers in doors, sealed and some foam filling.
If I remember correctly, LPF of 1.6 with 12db slope and HPF of 70 6db slope for L16RN and HPF for MDT12 of 4k with 6db slope. Love some constructive criticsm on this.
Also, left rear door speakers hooked up, so they ran as mids only and I think they were dragging down the rest of the system, lots of distortion and adding mid coloring. I told the owner I didn't like them hooked up and if he finds that stuff doesn't sound right to disconnect them or have me do it to see if it improves the sound, but the first time I test ran the system they were hooked up as only tweeters and definitely was an improved sound.....I'd rather they not be in at all. Oh well.
Over all it is a very capable system that could benefit from a few more tuning options to really get it tuned in and maybe a bit more high end subwoofer setup. For the budget it is killer.
Let me know if I missed anything or criticsms or anything, I'm a novice at this stuff in its entirety.....
Maybe I should have tried a LPF at 1K with 6slope and put the tweeter at 2.5 at 12 slope...... didn't even consider that an option......
If I work with him soon I'll definitely ask to fiddle a bit and see if it helps if you guys think that is a viable option for improving. Also wondering if the amp was running out of steam for all those drivers as they are 8ohm drivers and the amp is rated to 75@4ohm....I mean it's plenty for most and where it was starting to sound bad was just about maxed out.
Thanks guys.
