I've been messing with my mini dsp on the same build I've been working on the passive and so far these are my settings in the pics. The FR graph looks great on measurements but the woofer has some funky stuff going on where it distorts and has a definite buzz to it. I'm not certain what is causing it to do this. I had one minidsp running my passive mains and the other 2 channels running my subs and it worked flawlessly. For some reason when try to go full active it doesn't like it. I have a 50uf npe cap on my tweeter for safety but that's the only passive parts.
I haven't changed the parametric eq at all. But lowered the tweeters output by -6 db. Just to try something different I tuned it flat with the parametric eq and barely changed the output eq for woofer and tweeter. It did something similar with the buzzing. Any ideas to what is happening?
What amps are you using (and are they grounded)?
What are you using to power the MiniDSP?
Does it only do it when your laptop is connected via the USB cable and the laptop plugged into the AC brick?
There are both plugged into a nice surge protector (3 prong), the amp is 3 prong power too. The minidsp is using the usb powre from a 4port usb power hub.
I have the bare board, will need advice on addressing that. If it goes well, I might pony up for a bigger version.
