Dayton DA-115 4 samples
Vas by delta mass, beat on for 24 hours with 15Hz tone exceeding X-max
MFG
  • Impedance8 ohms
  • Frequency Response60 to 15,000 Hz
  • Sensitivity84.9 dB 2.83V/1m
  • Resonant Frequency (Fs)60 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)0.7 mH
  • Mechanical Q (Qms)2.6
  • Electromagnetic Q (Qes)0.49
  • Total Q (Qts)0.41
  • Compliance Equivalent Volume (Vas)0.155 ft.³
  • Mechanical Compliance of Suspension (Cms)1.1 mm/N
  • BL Product (BL)5.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)6.6g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)53.1 cm²
Sample 1
Re         =      6.6853 ohms
Fs         =     69.5598 Hz
Zmax       =     49.3078 ohms
Qes        =      0.5527
Qms        =      3.5238
Qts        =      0.4778
Le         =      0.4404 mH  (at 1 kHz)
Diam       =     82.5500 mm  (  3.2500 in  )
Sd         =   5352.0971 mm^2(  8.2958 in^2)
Vas        =      2.9773 L   (  0.1051 ft^3)
BL         =      6.1502 N/A
Mms        =      7.1550 g
Cms        =    731.6698 uM/N
Kms        =   1366.7367 N/M
Rms        =      0.8874 R mechanical
Efficiency =      0.1704 %
Sensitivity=     84.3316 dB @1W/1m
Sensitivity=     85.1113 dB @2.83Vrms/1m
Sample 2
Re         =      6.8547 ohms
Fs         =     68.8860 Hz
Zmax       =     48.8000 ohms
Qes        =      0.5899
Qms        =      3.6099
Qts        =      0.5071
Le         =      0.4450 mH  (at 1 kHz)
Vas        =      3.3623 L   (  0.1187 ft^3)
BL         =      5.7000 N/A
Mms        =      6.4603 g
Cms        =    826.2757 uM/N
Kms        =   1210.2498 N/M
Rms        =      0.7746 R mechanical
Efficiency =      0.1751 %
Sensitivity=     84.4498 dB @1W/1m
Sensitivity=     85.1208 dB @2.83Vrms/1m
Sample 3
Re         =      6.9739 ohms
Fs         =     67.7901 Hz
Zmax       =     48.2939 ohms
Qes        =      0.6004
Qms        =      3.5574
Qts        =      0.5137
Le         =      0.4499 mH  (at 1 kHz)
Vas        =      3.0208 L   (  0.1067 ft^3)
BL         =      6.0609 N/A
Mms        =      7.4251 g
Cms        =    742.3423 uM/N
Kms        =   1347.0874 N/M
Rms        =      0.8890 R mechanical
Efficiency =      0.1473 %
Sensitivity=     83.6992 dB @1W/1m
Sensitivity=     84.2953 dB @2.83Vrms/1m
Sample 4
Re         =      6.7091 ohms
Fs         =     69.9648 Hz
Zmax       =     48.0408 ohms
Qes        =      0.5315
Qms        =      3.2741
Qts        =      0.4572
Le         =      0.4225 mH  (at 1 kHz)
Vas        =      3.2377 L   (  0.1143 ft^3)
BL         =      6.0077 N/A
Mms        =      6.5037 g
Cms        =    795.6452 uM/N
Kms        =   1256.8416 N/M
Rms        =      0.8732 R mechanical
Efficiency =      0.1960 %
Sensitivity=     84.9415 dB @1W/1m
Sensitivity=     85.7058 dB @2.83Vrms/1m
kennyk
  • edited October 2016
    A little variation  from PE specs. Did you test them cold, out of the box?
  • He beat 'em up, from what I read.
  • I meant, did you also measure them out of the box.
  • Beat them for 24 Hours at 15Hz.. I turned the level up until they started to audibly strain then backed down a hair until they stopped and left it there. They have a surprising amount of excursion limit. I took all four samples and re-ran all of my sims and the variation from using the datasheets was less than 0.5dB. I got worried for s second, but in the end I think wherever it was off (like Fs) the Vas came in lower overall making up for it so the cab requirements stayed the same. One note, once backed down out of the "oh shit" range, they were extremely quiet mechanically which was surprising. Usually inexpensive drivers, even metal ones, can be a bit "whumphy" when pushed hard, but not brake em' hard.
    I am having an issue overlaying on my OOOOOOOL' WT2 so I cannot post the plots at the moment, but the Z curve is very smooth with zero blips. If the FR performs as expected these will be crossed around 1K and will be moving an 8" PR. Seems they will do Just fine.
