Had to make a mounting plate.
found out my coil is a 1/8” short now. So I had to use a twice as heavy coil.
My 8” next to a Dayton HO 8”
Distortion at 6” in a .75 cu.ft. Sealed enclosure
Blue no x-over
Red with simple 2nd order
measurements in sealed box @ 15 inches
https://www.jfcomponents.com/
74gram dvc, copper coil on aluminum former.
34.5gram 6ohm, copper coil on kapton former
23.5 gram 8ohm, aluminum coil on fiberglass former. I had these made for me from Precision Econowind. I didn’t get to use it because I didn’t add the spacer in. I ordered some different basket so they can be used.
I need to add that this is really, really cool.
Graph 2 woofer Distortion
Graph 3 woofer FR no x-over
