You know, recently,
@joeybutts was "glowing" about some drivers he got in trade from me, and for myself, I just kept thinking that DIY is probably the only place ever where trades result in both parties with a big grin. I'd really been feeling the need to upgrade my little TC Sounds Epic 8 sub, so I reached out, and it turns out that Joey had a Titanic3 12 inch sub he was ready to part with. So I got this:
Not much in the WAF department, but we all know how to fix that! The box itself was 1 inch MDF, with a plywood insert to screw the sub in.
A little veneering with some recon macassar ebony resulted in this:
The finished version has a few flaws. Lesson for me is not go down to the shop when I've had "a few". Ended up drilling a hole in the surround, but I think that the bicycle patch I applied will work. In any event SWMBO loves the look and loves the sound, so I'm golden. Thanks to the community, guys!
AND THANKS JOEY
Excited I have a full projects worth of drivers! Thank you sir! Thanks for doing that sub justice
I tried brushing on Deft lacquer, but didn't get the results I wanted (TBH, I used the cheapest bristle brush they had). So I sanded much of that off, and spraying 2 coats of rattle can Deft lacquer. Easy, fast, and looks good.
Recently I found a new hardwood supply shop in town. Veneer prices were awesome - $45 for quarter sawn oak - $60 for sapele with no shipping fees! I said "you guys are spoiling me!"
re: screwdriver malfunctions
I initially used "shoe goop" on the back side of the hole, but that was the very last bit of the tube.
As far as I can see, shoe goop should be a great material for this kind of repair.
