Diameter= 7.90 cm
Free air impedance:
Simulated in 6L tuned to 55Hz - pretty decent extension for a 4", and the two samples are pretty close in the models.
I took some FR measurements a while back.
So to get a rough idea of things, here is the baffle signature as calculated by Response Modeler:
Here is the farfield - I don't remember exactly the distance but I almost always measure at 1/2M:
Here is a nearfield:
Here is a distortion plot taken at 1M, 90db. It goes to hell at that volume level.
As can be seen from the variety of measurements, it exhibits a "cliff" in the response similar to many other cheap (and some not so cheap) drivers between 1 and 2K. While this can complicate crossover design, at least it does not have a corresponding breakup to deal with.
One thing to observe, as well, is that this distortion measurement is taken on the wide open baffle - it is sure to be better in a properly design enclosure meaning it is probably pretty solid on the bottom end.
