Ok, I seen these things in pics several times but now I can't find those pics, or what the darn things are called.
They are red slotted blocks that hold the wood at 90* while the glue is setting.  Something like a right angle assembly square.
What in the wide world of sports are these things called and where can they be found?
Woodpeckers Precision Woodworking Tools BC4-M2X2 Box Clamp-M2-Pair https://www.amazon.com/dp/B0062C76QG/ref=cm_sw_r_cp_apa_9DJEAbZZN1KCT
Bought two of their 'corner clamp with quick release' for $10. Got about three uses out of them till one no longer tightens down enough to hold the wood in place. Not sure how square they were either ... or it could have been the dummy operating them.
Pretty sure it was the woodpeckers, or something similar, but at that price, I might try that diy first.
Is there a trick to getting good 90* corners all while maintaining enough pressure the glue bonds good?
What do you guys use, and how do you get everything squared up?
Smaller enclosures, I miter, including the back. Use 1.5" painters tape. Keeps every thing square
I also have the larger corner clamps from menards like wolf craft or something. They are usually $26 but got them for $14 each a few years ago.
Izzy's clamps work nicely as well. I made one but Im too lazy to make more at the moment im too backed up.
Didn't see any of those 'clamping squares' at either place.
Was going to do the diy route but with my luck I'd never get the things square enough to use.
One of these days I'm going to have the good stuff! If only I'd been born rich instead of so damn good looking.
