I decided to start this new thread to share pictures and details of my new amp project.  Unlike most of my projects this one will NOT be housed in a hardwood, 4 sided case, with an aluminum top and bottom.  Our IT Manager at work called me a few weeks ago and asked if I wanted an old UPS unit that he was upgrading.  Hating to see anything with potentially useful parts go to the scrap heap I said "Yes!"  Nothing inside except the muffin fan was worth keeping... but the case!  A perfect case for an audio project!!!!  Of course it'll need some modification, specifically a new rear panel.  I'll snap some pictures of it.
The model of amp board I purchased was the CDA-250:
http://www.classdaudio.com/cda-amplifier-modules/cda-250-power-amplifier-module/I already have a 400VA 35-0-35 VAC toroid transformer and a small power supply board (rectifier and cap banks).
Since I run a single ended signal chain, I am going to sister a larger finned heat sink to the existing one, and I don't need external gain pots, the CDA seemed appropriate.
There maybe other differences I am not aware of besides the $100. Lol
I've read the irs2092 can sound lean on the bottom and a little bare otherwise. Also heard that of the Hypex ucd and n-core offerings but with a full bottom end. I don't know if there's as much a difference as some make or if it's a fly shit in pepper thing. They all spec fantastic, the n-core exceptional.
I'm in the market for an affordable drive anything amp that sounds good, (full but controlled bottom and smooth but not subdued mid/treble, I hate glaring treble) where I can close my eyes and reach out and touch the performers.
What have you tried, or heard, and your take on them, good or bad.
Is it possible to mate something like the irs2092/ICE/Hypex with something like the tube pre your working on, and have the best of both worlds?
I see you said you will add another heat sink, do you plan to expose that on the case or keep it inside?
I worked on it a little today. I've completely switched up the layout. Now the amp board is mounted in the front right compartment (where the transformer was in the first pictures). I've cut an opening for a fan on that partition wall. Pics to follow.
