I am not going to write a lengthy review by any means, but I will just say that this:
https://www.amazon.com/gp/product/B01HERNVFM/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1...is much, more better than this:
https://www.parts-express.com/dayton-audio-dta-120-class-t-mini-amplifier-60-wpc--300-3800Granted, the FX Audio will not run a pair of speakers - but it is light years above the Dayton as a headphone amp. Currently playing Mark Knopfler's excellent "Privateering" from HD Tracks through the Akai cans Nick steered us to.
I have played this album many times through my Sennheiser/DTA combo before and this cheap Akai/FX Audio are on par with my cheap Sennheiser. Keep in mind my Senn's are an entry level model, I forget which. I swapped gear around a few times to be sure, but I do prefer the Aka/FX combo.
Anyways, I have spent far more on way shittier SQ.
Assuming you're just comparing the headphone output, how much does the sound worsen when you run your new FX DAC through the Dayton amp and plug your headphones in, compared to plugging your headphones directly into the FX DAC? If it sounds about the same, then you can assume that your previous source feeding the amp was the weak link.
Take the brief review for what it is worth, or leave it.
I'll leave it. I'm sure the FX is a great product, but the comparison makes no sense to me. Compare your new DAC to your old DAC, not your new DAC to your power amp. You seem convinced that the Dayton's headphone output is poor, and it probably is, but it sounds like you didn't make a comparison by plugging it into the new DAC.
There's plenty of images of the guts online, it looks like a pretty nice unit.
Here ya go:
https://www.head-fi.org/threads/fx-audio-dac-x6-2016-release-potential-sub-100-king.809203
The price was right on the FX Audio unit, unfortunately Amazon Canada doesn't sell it, but I ordered from ebay for CAD$75, which is about 1/4 of the price of the Sabre DAC I was looking at.
My headphones are Master & Dynamic MH40, which probably deserve better than the Focusrite 2i2 headphone jack.
I also have a pair of Sennheiser Momentum s (over ear model), but they just sit on the shelf now collecting dust.
I have it in gunmetal and black.
I dug up my old highly modified Zhaolu D2.5 (AD1852), it still works however I had salvaged the output stage for another project, so it has nothing after the output filter stage, definitely no high current headphone amp to do a direct comparison with headphones to the FX-Audio. I do have a few LM4562 in the bin and a pair of BUF634, maybe I can whip something up on a breadbaord for testing.
The only bad thing I saw when looking at info of the FX-Audio DAC-X6 online was the OP275 used in the headphone stage appears to be a mediocre op-amp, curious why it is used here. I do have a LM4562 in SOIC package, I may try a swap after reviewing the circuit, and perhaps a few capacitors along the way if needed.
I am finding a slight sibilance in the Treble, perhaps just because it's more prominent now, well see if I still feel the same after a few days of use.
My biggest complaint out of the box is the length of the power cord. Its barely 3ft which gets from a power bar on the floor to the desk top and no further. It is just a 12V DC supply, so I'll either find a suitable replacement or DIY a fix for this problem.
And if anyone is curious, yes it works fine in Linux as a USB device, though I had to make sure the output is set to spdif for the volume control to work. Minor detail.
Under Windows 10 the situation is actually worse, as a USB device the volume control does not work at all, and I got one heck of a surprise when I plugged in my amp and found that the volume control on the DAC itself is only for the headphone out, the line out at the back is at full volume all the time!
The main op-amp in the chain is nice in that it is a DIP package with a socket, so swapping for a different part is simple, noth that the OPA2134 is a bad choice by any means. Unfortunately they did not supply a DIP package or socket for the headphone amp, the OP275 used here is a SOIC. Why there isn't another OP2134 here is beyond me.
Some pretty blue Elna caps are the DC blocking, unfortunately with this device being so small it would be difficult to replace them with a poly cap. A second pair of Elna caps find their way towars the headphone amp, reviewing the circuit it looks like they can be safely removed (bypassed)unless for some reason your device plugged into the pre-out is backfeeding some DC voltage. With nothing connected there is 0V on both sides of these caps (these are C86 and C91). You'll want to leave C77 and C87 in place.
Wow - so much for QC. Maybe I need to crack mine open too.
Thanks for your explanation of the circuit on this. I had read on a Head-fi thread that changing the voltage on that LM317 rail could improve the sonics.
https://www.head-fi.org/threads/fx-audio-dac-x6-2016-release-potential-sub-100-king.809203/page-6
I have learned to take most of these "mods" with a grain of salt. Do you have any thoughts on this one?
Thanks!
In his video if he moves the unit it goes off and then on.
At least that is an easy upgrade :P
If you really want to go all out, iFi makes some "audiophile" low noise wall warts for about USD$50, effectively doubling the cost of this DAC
