Audible Physics just released a new set of high end drivers, RG100.4 and RG100.6. 4" OD full range drivers. The .4 is a 4ohm and the .6 is yes a 6ohm. Specs are slightly different as the 4ohm is intended for car audio and the 6 for home.
Here are my imp measurements vs factory
Fact A B
nom imp 6
Re 5.6 5 5
Qes 0.57 0.56 0.51
Qms 1.71 1.64 1.55
Qts 0.43 0.43 0.39
Vas 2.07L 1.80 1.72
Spl 85 86 85.5
Bl 3.69 3.7 3.71
Linear P-P 10mm
Excursion
Max excursion 15mm
Sd 39.5 sq cm
OD 100mm
Geoff did you measure the tweeters as well?
