Ok gentlemen I am going to attempt my first design with the SB26STAC tweeter and Tang Band w4-1720 4" woofer.
I want to shoot for a crossover point of 2000-2200. The tang band woofer has wonderful low end but gets over tasked
at high volumes playing into the midrange and my goal is to alleviate the burden of having to play from 20hz-4000hz
and drop it down to 20hz-2000hz. From what I read in Bagby's post about the SB26STAC going below 1900 on the sb26
introduces elevated distortion levels so I wanted to keep it above that.
The process I don't have full comprehension of. So I wanted to ask for some input. Here is what I understand so far.
Craig S was nice enough to run me through this for an hour or two a few years ago but my memory is foggy.
If any of this is wrong or can be add too I would appreciate any insight.
1) Take FR measurements on tweeter and woofer on each speaker (A and
    A) Take near field FR measurements. Mic height at Tweeter level. Approx 1/4" from tweeter. Measure Tweeter and Woofer individually (without moving   mic from TW. height)
 Take Far Field FR measurements. Mic height at Tweeter level. Approx 20-27 inches away from tweeter (IS this correct?) Measure Tweeter and Woofer individually (without moving mic from TW. height)
  C) I faintly remember taking both drivers measurements at the same time but I could be wrong (yes or no?)
2) Take DatsII zma measurements in box (this im a tad unclear of; as dats gives me random measurements at times)
   A) Take dats measurements on tweeter and woofer in box for A and B
3)Import these measurements into FRD blender (never used this program before)
4)Import blender file into PCD along with individual non blended measurements
6)Find Acoustic centers (I can't remember how to do this) but think I remember it was based on when you take both measurements at the same time.
7)Start to fiddle with PCD
There's a lot in your post to respond to. How about we just start at step one and people can chime in step by step as you proceed through this design?
Once I get the drivers mounted in the actual enclosures with wires running out to the real world I use DATs to measure each driver's impedance curve. Hook up the allligator clips to the driver under test (DUT) wires and hit the "Impedance Sweep" button and let it do its sweep. Then hit file/export/save as a .zma and give it a name. Something simple like "Tweeter A".
You don't have to measure the impedance first, but I do because if I have an air leak or weak faston connecter it likely will show up in the curve and I can correct it before moving on to the more involved frequency response measurements.
I'm stuck between wanting to veneer or finish the baffle to start measuring. Probably should measure them so I have more time to fiddle with the design.
Also watch out for air leaks. I've been burned more often than I care to admit.
As I posted the other day I've had a string of port issues where I had to figure out how to shorten the port.
BTW I was able to help Tom Z by trading FRDs and walking through the measurement process. I'd suggest dong that with one of the "fellows" here. It's so much easier to get immediate feedback as you go.
Ok I'll try to post my measurements here and if there are any takers I can email the files to see if I have everything setup correctly and measured correctly.
Grey, yeh it's 1/8th maximum. One might be a tad deeper because the large 45 bit caught once and shot the baffle across the garage.
This is the error window I received. If I need to remove the woofers for this would it be better for me to just do the omnimic measurements before removing them? It's kind of a pita to remove rear mounted woofers lol.
The cabinet is 6" W X 10" H X 11.75" Deep with 3/4 inch material. I was shooting for like 56-60 vent tuning frequency with 2x 1" round ports I don't remember the length but i think less than 5 inches.
Speaking of, I really need to build several test enclosures for exactly this purpose. David Weems told me to do it that way 20 years ago, and he wouldn't lie.
Like Chuck said, you only need to run an impedance sweep on each driver to use in PCD. That setting un DATs makes no difference for that.
I've got the the Impedence data. The tweeters appear a tad different however one is brand new and one was used for testing and minor break in. Hopefully that is the tiny difference.
Questions on near-field measurements
1) Do I just take 3 measurements per speaker nearfield?
(A)Tweeter about 1/4" away
(B) Woofer with mic position the same at Tweeter level
(C) The Woofer Nearfield about 1/4" away. (since woofer is rear mounted this may need to be altered but I don't know for certain but my #2 question refers to this)
If anyone cares to expand on the reasoning behind this it would be appreciated.
2) As far as distance for measuring nearfield is 1/4 inch away from the tweeter suitable and do I keep the mic position exactly the same for woofer (distance wise) if I just lower the mic it will be about 1-1/2" or 1-3/4" away from woofer nearfield.
Far field measurements
1) Do I need to use 1 meter or can I go a little less distance wise?
2) Do I need 3 measurements per speaker on this as well at Tweeter height @ X distance
A) Tweeter
My understanding is that having these 3 helps determine the Z-offset
Thanks in advance.
