Anyone heard or used Visaton W250S-8?
13»
  • Could do a MLTL
  • Right on John, start designing one for me!
    OD
    10" wide
    24" high
    10-14" deep
  • No problem with Horn Response. OK to use the published NE225 specs?
  • Yes.  I broke mine in and they measured very close to manufacturer specs.  Just keep that cool rear slope like in my concept ;)
  • And just to be concise, I have the NE225W-04 drivers.
    Good one.  I'll give you the basic length and locations you can fold it anyway you want.
  • PWRRYD said:
    Tom S tried to listen to them Sat night at the hotel informal.  It was too bad it was so loud in there.  He really couldn't hear how they sounded.
    What I could hear, I really liked! You pulled off the swap from ND woofer to the Peerless TC perfectly. I would love to hear them in a near-field configuration. If you PM me the crossover, I'll build a pair once I'm done building some acoustic treatment panels for my man-cave.
    It looks like you're gonna have some serious thump with this one. I'm not well versed on open baffles. Would having the semi-circular top exacerbate diffraction artifacts with the mid driver or is that not as much of an issue with this type of design?
  • Here's a first pass.  I did not try to fold this into your box dims, but the volume is the same.  I can fold it later if you want to try first.  F3 of 30 Hz seems pretty good compared to a std box.
  • Is that sim correct above 100 Hz?  Not liking the FR from 150 to around 600 where I planned on crossing.
  • I think if you used 12dB slopes and a knee tweak that it could still work depending on the room and baffle interaction.
  • Does the Sim include stuffing?
  • The sim is theoretical and includes stuffing.  The crap above 300 hz is port and box resonances "leaving" the port.  Other than the trend, I ignore most of this.
    Stuffing between the driver and port can also help damp down any spikes but it can kill the port output.
    Note that this is the same size (maybe a bit smaller) as your bass reflex box.  If you not like it you remove a center divider.
  • John, I really appreciate you working on a MLTL for me, but I think I'll go for the standard BR design.
    Flame suit on here:   I've heard numerous MLTL's and never really felt they sounded any better than regular bass reflex designs with the same driver and roughly same enclosure volume.  In fact my "Agendas" project used a RS225-8 in a MLTL design Paul K. did for me.  It seemed to have too much energy in the 40 Hz area, then again around 200 Hz no matter what room it was in.
    I heard Chis Romeors design last weekend which used the same NE225W-04 woofer in a standard BR enclosure, roughly the same volume I am looking at doing.  I thought that project had a very nice bass response.
  • I tend to agree that there's not much advantage with most drivers.  This one clearly gave a 5  Hz drop.  My thought is with a single fold you can pull the center divider.  I'll sketch a concept.
    I don't care if you don't use it, I enjoy the design process.
  • A HUGE "Thank You" John.  I appreciate all the help and advice you give me and the many sims you do.
  • I'm Cad less tonight, so old school.  If you dare to go this way I'm sure in Cad I could figure out a slanted top.  My unibox F3 was 35.6 Hz, this sim was 30.6 Hz.
    I'm happy to help, you just happen to hit me when I've got some time.
  • Thanks John.  I'm going to try and figure out how to make that work with a removable baffle.
  • For my Aperivox build, I made the bottom of the box removable.  So between the bottom access and the woofer hole access, I bolted the box to the front baffle with lag bolts.  It helped that the baffle was almost 2 inches thick.
    One of the tricky parts was lining up the port hole.  There's probably a easier way but I ended up bolting the unassembled box front to the front baffle, installing the port tube, then drilling a pilot hole and routing everything flush.  After that I took everything apart assembled, box, painted, etc.,pita.
    btw, before the glue up I was able to to route a groove in the wood to hide the wires to the mid.
  • I’m for the rounded top.
  • Thanks Rich, that's the one I'm going for, maybe a few inches shorter overall though.
