Box Theory
There has been an expressed interest in future box design. CNC and 3D printers are at the forefront of the discussion. This thread will be a sounding board for new ideas to improve box design.
  • To start the show on da road, I'm not aware if anyone adapted room diffusers to the interior of boxes? I mean hard irregular shapes, not mattress toppers.
  • Im on the phone right now, but when I get near a real PC soon, I will talk a bit about some of my thoughts.
    kennyk
    I recall a Speedster build where somebody did exactly that on the inside of the cabinet but I believe each block was cut and glued manually??
    My signature goes here
  • Was it posted?
  • Yes, posted on Techtalk... Need to look for it. The blocks were of random lengths on the inside.
  • So......constrained box with a solid diffuser layer.......maybe?
  • Would you need stuffing?
    I’m sure it could work but you’d have to do some math to figure out the box volume. I’m sure there’s 3D modeling software that could do the calculations but I’m not in that camp. Way over my head.
  • You can use the average thickness.......close enough. :3
  • Cad or Rhino can calculate the volume of the complex 3D object. It has to be 3D modeled properly. What's known as watertight model.
  • Im thinking about trying something like this. The front will have a recess with like 3/4 or so overhang to mount a baffle inset the width is not correct in my shitty drawing. I was just spotballing. I like the bottom right design and you can see the baffle on the too right.
    This would be a translam deal. If you got any suggestions im trying to come up with something.
    Trying to figure volume, or effectivenessm
  • Tony Gee (humblehomemadehifi, tg-acoustics) has done it in a few different designs, but a quick, once-over of either website didn't bring it up, I remember they used SS Illuminator woofers. It wasn't a full-blown QRD panel inside the enclosure, but it was unequal length boards running vertically with angled sides.
    I've considered making a midrange tube with a "skyline" style diffusor panel in it, just for the frequencies that the midrange is responsible for, but that would be really difficult to even estimate, really.
    If you could design 2+ "slices" with the same exterior and flip-flopped interior that would work really well. I've seen several people build them like that, it not only looks really cool, but I'm sure it practically kills any and all standing waves inside the enclosure. Looks like you're off to a good start.
  • Tony Gee is hilarious. Seriously, he is always good for a laugh.
    greywarden
  • Translam layers can be differing thicknesses. You can create this effect in the interior.
    greywarden4thtry
  • Ooooooh lookit my cap!
  • Lot like that other "DIY" guy who is nothing but a shill for Jantzen... and has convinced the world his opinion carries meaningful weight...
    greywardenR-Carpenter
  • Or Peter Norbaek and his amp killing bullshit designs...
    greywarden
  • Sorry, but there is nothing Peter and Tony and Troels know that anyone in a hotel room in Grinnell doesn't know.
    greywarden
    I had to look that one up, but HOLY SHIT that impedance is madness!!!
  • I never have understood why Peter does what he does in the xovers. Comping the Fs of a woofer? Why? That's just not necessary 99x out of 100. I can understand comping a mid's fs a bit in a 3-way with shallow slopes, but not like he does.
    Yes- Troels is a bit of a shill, ain't he? "Look at how much money I was given to build these!"
    Tony is a bit different for sure. I don't always agree with his preferences in terms of his infamous list, but about 7/10 in terms of what caps I've tried, I agree with him. If I hadn't experienced it more than once on different builds- I would likely say they make no difference as well- but then I'd be wrong. However- the extremes he goes to I feel are grossly overstated, and a lot of the time unwarranted, not to mention foolishly expensive. I recently read an article that F/F PIO caps will always fail due to an inferior construction method, and likely sooner than many others- yet- they are all the rage among loudspeaker modifiers just because they are "DWAYLOONT!"
    If you send me the file or sketch with dimentions, I can plug it in Rhino, extrude, say to 0.75" and give you exact volume.
  •      After reading some of the posts here, I think I look somewhat skeptically upon "new" (CNC, 3DP) technology.
         When we build, hell when a company that actually cares about sound builds a loudspeaker cabinet for that matter, what is looking to be accomplished?
      Acoustically, we are looking to make a cabinet that can dampen the rare-wave of the drivers, not resonate to any given frequency and if it does, shuts itself down very quickly and many other things to basically not contribute to the sound.
       Visually, it has to fit a theme, room, or just be a work of art...The latter usually causing more issues than it solves in terms of design, measurement, and power response.
    UNLESS
       A waveuide is built-in to the cabinet, the cabinet tapes to dampen the rear-wave off the woofers, or is purposefully designed to contribute in a positive manner. Unfortunately, this takes extensive research to accomplish properly to avoid the head-in-a-vice vs. fall apart sound stage, and every other issue associated with waveguides that are not always measurable in the frequency domain.
       Vivid does this with near perfection, but their speakers do not have a look that appeal to many....At all.
       Empirically, where does this leave us. CNC can make complex patterns far easier to cut. However they can create as many problems as they solve as I have recently come to find out and are not always "easy". They have their place in cabinet making, and when getting the shape right for the Diomede, the modeling Roman did was extremely valuable.....Also, damn those drivers fit like a glove!!!!! Using the extremely dense and thick rangerboard would have been a GIANT pain to deal with without it. Repeatability, predictability, and assurance is certainly gained with CNC making is a huge assett to this hobby if one made the investment...Though it does not play to the "My $200 build beats $4000 commercial speaker" argument because the time and investment to get a CNC up and running properly and usefully. a 'matrix' style bracing scheme could be done with CNC which I think could be the largest single advantage of new cabinet technologies.
       3DP is hard to justify at any measure... yet. At the end of the day it is plastic. Plastic parts WILL ring. If you dampen them they become large. Inside the cab you say? Now you are looking at ringing inside the cabinet which can cause a delayed reflection on the back of the cone distorting the spectrum of the driver. This MAY NOT be visible on the Z sweeps or Fq, rather on the waterfalls and if you have no other reference for it can easily be missed. I guess the advantage is you can make a speaker, or parts, look very cool.  Further there is a cost associated with 3DP...
         For me, I am still left with my primary worries during cabinet design. Internal reflections, internal vibrations, panel vibration, diffraction, internal dampening, and panel dampening. I know Wilson gets hate, as well as *some* others, however them, Wilson-Benesch, Vivid, B&W among others have developed proprietary materials (usually a concrete/rubbeized/poly-thingy mix) which have a far greater advantage because they can simplify bracing schemes and cabinet design. Well, simplify the requirement for reflective points internally...anyway...
       At the end of the day, more is not always better, and because one 'can' do something regardless of how cool it looks, does not mean it should be done. No matter what, the science cannot be forgotten. Leveraging new technology can be great if done with purpose, and reason that helps to serve and is more advantageous that previously established methods that have been developed, and massaged into useful ways to overcome fact-based problems over the corse of years both efficiently and effectively. Worse, you need to be able to compare the new ideas to to a reference to truly understand if it is better, worse, or the same.   Over-engineering has no real point. More complex ways to do the same thing does not make it better, in other words. However, there is much to be gained and learned with these 'new' tools.
       The last can of worms is what we have available to us as DIY-ers. I think to fully leverage the advantage from a objective, measurable standpoint we lack many of the measurement tools required. This would take a pretty large investment on our part, and throw us into doing research (i.e. building then testing, measuring and interpreting) vs. building awesome loudspeakers. Its a fine line and much of what *can* be gained we cannot quantify simply because it is beyond the scope of our measurement capabilities.
       So in the end, its a careful balance. We all like cool new toys, and cool looking things, however in this hobby, purpose counts and it is all too easy to create as many problems as you can solve...Some of which may not be easily caught by our capabilities to acquire useful data.  I want to see where 3DP and CNC go in the hobby, the latter being far more useful as of now, because I think we are at the beginning of both and there are great things to be had long-term.
  • P.S. A friend of mine went through the painstaking hours and expense of building Troles 'Elam'. They are 200lb paperweights as it is NOT the speaker his uses to listen... So there's that.
    I
    greywarden
  • edited October 2017
    Well, CNC decreases intensity of labor (sorry, it's a bit Marxist), increases precision. But in the end, it's just a tool. A lot depends on how well you 3D model and your actual woodworking experience. I can put a 3D wizard modeler college kid on my machine and he/she will most likely set MDF on fire or break the bit.
    PWRRYDjhollanderkennyk
  • Here's what my next set of speakers will have. Internally, I've been messing with this diffusion thing for some time now. This is where I've been steered.
    greywardenkennyk
  • With respect to internal adsorption I thought open corrugated cardboard flutes would be a good combination for wall stiffening and adsorption.  Wouldn't be to bad on weight either.
    kennyk
  • Just peel off one layer of the cardboard and stick to the inside?
  • Just address a few points brought up...
    1. All materials will ring, any company advertising totally inert material are selling lies. Pushing the ringing out of the audible spectrum is what they should be saying, but it sounds fancier to say otherwise. Plastic is completely capable of performing resonance free in the audible spectrum.
    2. The costs associated with starting up 3D printing is in point of fact lower than traditional woodworking tool setup. It also offers considerable off-loading of labor - while it is running, I can do other things. Traditional building techniques requires the laborer to be at the work the entire time. I have limited time to play with sawdust these days.
    3. I'm not sure there are magic things going on in a loudspeaker that we can't measure. I have heard this claim from a few people now, and no offense it is a claim generally made by those selling or advocating audio components priced very high. With the tools I possess I can measure many, many, many aspects of loudspeaker performance including small changes in temperature, panel resonance, and the more traditional on and off axis behavior and the impedance. I am going to pretty much call bullshit on the "can't be measured" aspects, and agree to disagree on this topic - I will not be engaging in conversations that rely on magic.
    4. i am not going to rule out internal diffusion, but my tendency is to believe internal absorption is worthy of a more serious look. I mean, we rely on the backwave for some of the good things that happen, and the frequencies that we can generally diffuse or absorb due to wavelength inside a cabinet are already generally outside of the passband - or should be, anyways. I have to give this one considerable thought.
    5. Over-engineering has brought us to this point, and sorry Mike - 3D printing is absolutely viable and capable of a fuck of a lot more than your "at least they can look cool" snipe. Your entire post reads to be very condescending to DIY in general, and it is a tone I run into time and time again at Axpona. "Awww you DIY, how cute".
