Zobels, thoughts
a) effective choice for dealing with impedance rise for mid /tw crossover range, or
b) yes, but superior end design / sound without one in place
c) depends upon…
  • It really depends on the drivers and the system design. Sometimes it helps the rolloff by damping the knee, even if it's not affecting the natural Le curve.
    tajanes
  • Generally speaking a Zobel's intended purpose is to flatten the impedance, which is not really an important feature if using a modern amp. If using a tube amp, you may want to flatten the impedance to keep a near 8 ohm impedance across the spectrum.
    If it helps the response of your system, then by all means use a Zobel.
