SLS-830667 as a woofer in a 3 way?
edited January 2023 in DIY
Has anyone used this as a woofer in a 3 way?
I’m planning to cross over to a coaxial, probably 200-300Hz. Box volume is 20L; and it can be sealed or vented. But since this project involves enlarging a pre-existing woofer hole; it’s a one way street once I do that.
Wondering if others have used this woofer. What was your experience?
  • I haven't but I did just recently get a pair with the intentions of building a stand mounted 3-way. It seems well suited to a crossover point up to 600+ hz, so it may be able to pair to a dome mid that I have on the shelf. Good luck with your plans!
  • In my novice experience, the SLS line is a great all arounder. I particularly have experience with the 830946 and it does fantastic sub bass to midbass, if i remember ~400-500. I would think the 8” variant would be just as great, especially in the band you are intending.
  • Plugging the numbers into WinISD.. 20liters seems rather small for it in a vented arrangement. Giving an F3 of 44-47hz and an upper bass hump 2-3db depending where you tune the port. Sealed yields an F3 52.5hz
    Crossing over that low opens up other options.
    GRS 8SW-4HE in 20 liters Sealed yields an F3 of 40hz. Vented, tuned to 25hz yields an F3 of 29hz with a hump under 1.5db. Heck in that arrangement the GRS is gaining SPL in the region the Peerless is dropping out.
    I know F3 isn't everything, The Peerless could plain sound better (I don't know) and the GRS isn't exactly eye candy by comparison. Then you have 4 vs 8ohm
  • The GRS is very flat out to over 1K and anchors a 3-way just fine. However, the Peerless does have a shorting ring so should theoretically have lower distortion. It also has higher advertised Xmax.
    Still, a pair of the GRS wired in series solves the impedance concern and will offer greater output capability than the Peerless for just a few dollars more all-in.
    It is good having options. I had to restrain myself from buying a couple of the Peerless.
    Steve_LeeDrewsBrews
  • edited February 2023
    We are talking about the 8SW-4HE not 8SW-4 right? HE has rated linear xmax of 10.8mm vs the peerless 8.41mm.
    I remember you measured 8SW-4 extending past 1k, but I wasn't aware the HE would do that.
  • I was talking about the plain Jane grs 8", not the HE. Sorry for the confusion!
  • edited May 2023
    Just circling back on this- I acquired a pair and took some in box measurements- here is some data-
    Sensitivity on the low side, on the upside seems suitable for a sealed box, and can handle a LR2 low pass at up to 400Hz.
    BrannigansLawSteve_Lee
  • edited May 2023
    Not dissimilar to when Klang & Ton tested it almost 20 years ago. That’s some kind of amazing consistency…
    Hello. Would you be willing to share some details on this build? I am interested in using this woofer for a similar application
  • This driver was used as a drop-in for a spare test enclosure I had laying around to meet a true midrange coaxial that could only go down to ~400Hz. But after full baffle step compensation, and only 1 woofer per side I wasn't happy with the low voltage sensitivity 81dB/2.83V for a passive design, and the sealed box bass extension.
    If you wanted a sealed box I feel that the 830668 10" is the sweet spot of the SLS range.
    For 20L sealed or vented I would go with something else eg. B&C 8BG51
    I now believe that a single 8" woofer for a sealed box offers offers limited advantages over a 6.5" vented box...which may explain the ubiquity of the latter.
    Thank you for your response! Did your use case not give you much room gain? I wouldn't expect to have to do full bsc in most instances. I am hoping to pair them with TC9FD, which are already pretty low sensitivity, so I'm ok with a few db. TC9FD also has pretty limited power handling, so I won't need much output from the 830667. For mating to the TC9, it seems like a great match to me, considering I would like something sealed. Besides low sensitivity and limited bass, were there any other drawbacks in your experience? Also curious if you tried higher crossover points. I see in the graphs you provided it has rising distortion at 700Hz, so I'm a bit wary, but would be nice to take some of the load off of the tc9
  • edited June 2025
    @bryguy I got most of the way through a build with those two (+a tweeter). But something about it I just haven't been impressed with. So I have yet to actually button it up. I realy should though. I suspect it is an issue with the hard corners on the side causing some diffraction effects in the midrange. That and I can only wire up one of these big prototype crossovers at a time so the bass doesn't get augmented by the other speaker.
    https://diy.midwestaudio.club/discussion/2380/peerless-based-8-3-way-build/p1
    I'm crossing them at about 500hz. Resulting distortion is plenty below the 40db down point from my measurements so seems to be a non-issue down there.
    Impious
    Nice build! I'll definitely keep an eye on that thread if you ever resume development. If not I might be interested in buying some of those drivers off you :)
  • edited June 2025
    @bryguy said:
    Thank you for your response! Did your use case not give you much room gain? I wouldn't expect to have to do full >bsc in most instances. I am hoping to pair them with TC9FD, which are already pretty low sensitivity, so I'm ok with >a few db. TC9FD also has pretty limited power handling, so I won't need much output from the 830667. For >mating to the TC9, it seems like a great match to me, considering I would like something sealed. Besides low >sensitivity and limited bass, were there any other drawbacks in your experience? Also curious if you tried higher >crossover points. I see in the graphs you provided it has rising distortion at 700Hz, so I'm a bit wary, but would be >nice to take some of the load off of the tc9
    A low pass of 400Hz is fine.
    My room is around 3000cu ft. And my listening distance is over 10ft. I like to keep my speakers clear of walls. So I prefer close to full BSC.
    I'm also accustomed to twin 12" woofers, so there's that. So yeah, hardly a far comparison.
