Decided to paint just the bases before Indy, because they are easy to remove with just 4 screws. Each base is three parts bolted together: Top cap, middle curvy section, and flat bottom footer section.
Only had time for two coats of flat black so far. The forecast calls for cold weather (30's and 40's and possibly some snow too) in SE Wisconsin, so it looks like I may have to wait several days before sanding and spraying on the finishing coats.
I'm guessing you could still get them from. Other vendors. You might even reach out to Techtonic and see if they can sell you a few.
I might have 2-4 if you want them send me a PM.
Always a bummer when a driver we like goes NLA.
