DIY Coax
  • First, this is for Channing.
    This a slapped together 1st order.
    Second, the InDIY woofer will be the MCM 55-5665(same as Ben....damn). OK Craig?
    greywarden
  • Ok Kenny!  Thbbbbbb!
  • O ring doesn't work. Sounds interesting in 1st order. Never did a 1st order xo. Hmmmmmm....
  • That's not too bad +/- 5-6dB, it seems like that bump around 1500 would be rather annoying, though
  • Ran off a quick graph.................1st order.
    greywarden
  • How do these look?
    greywarden4thtry
  • Different crossovers?
  • edited October 2017
    No, same. I don't hear any difference that stands out.
    greywarden
  • Then again, my hearing is compromised.  :/
  • Thx Ben.
  • Finished!
    And a little wipe on poly.
    Bryan@MACTurn2Nicholas_23JasonPgreywarden4thtry
  • @kennyk you are king of the micro monitors!!
    kennykJasonP
    My signature goes here
  • And I love that you use plywood....fuck MDF.
    kennyk
  • That would be FMD, then, right?
    I still like MDF...
  • Ply is lighter. I don't go overweight on my luggage.
  • Maybe FMDF, I dunno.  For the new guys, always wear appropriate respiratory gear when cutting anything.
    You mean like no shoes, gym shorts and a maybe t-shirt?
    S7910kennykJasonP
  • Need some analysis:
    Sound fine, bass is there and not over powering. I like the mid/tremble, not over bright and not dark.
  • That is a 12dB droop at max; +/-3dB avg, but the HD goes up in that treble range too. It's likely sounding about right.
  • I was disappointed with my xo work at IOWA. So...reworked the 1st order and made a 2nd order......hmmmm. I haven't tried them yet, but if they show a distinct acceptable difference......maybe I will do a demonstration at the next DIY-NY/NJ.
    greywardenJasonP
