I've heard that certain songs and noise/tests can be good at revealing particular flaws in a design or driver or crossover. I've seen some recommended listening lists, but I haven't noticed much mention about what specifically to listen for problem-wise and I'd like some guidance on other listening test using noise or songs or whatever else.
Are there some songs or clips that are good at revealing frequency peaks/valleys or generally unnatural frequency response?
Is there anything I can listen to that'll be really good at revealing distortions?
Is playing pink noise while moving around and trying to listen for obvious "shhweeiiiiw whoosh" of comb-filtering and notches a good way to "test" for phase/alignment issues, or are there more effective listening tests?
Are there any other major speaker problems that can be heard and narrowed down through some careful listening tests?
What are some important pitfalls to lookout for when trying this?
I think I'd like to become a more effective listener with a better ear (though I'm also a little afraid that ignorance is bliss). Teach me your ways. Empower me to put off buying measuring equipment and learning to use it for as long as possible.
Answers
I also think marking this as related instead of DIY might've been a bad choice both because it may get less DIY attention and because it's technically for trying to help choose between drivers and tune crossovers. Not sure if that's related to DIY or direct DIY.
I'll see if I can change the format to something a little more accurate and maybe able to get more attention.
For instance, I know that Bonnie Raitt has a tendency to be a little bit sibilant on her "esses" - so if I hear an objectionable level of that, I'll tweak it down a bit. Similarly, you will find some bass torture test tracks.
There is a long thread on Parts Express Tech Talk for suggested tracks. I don't agree (or know) many of them, but that's a good starting point for exploration - you probably have a few of the albums in your personal collection.
Hope this helps.
I once had a set of EPI (I think) speakers that used 2 midranges side by side.
The sound changed drastically if you moved from left to right about a foot.
That's comb filtering!
I have not noticed a severe problem like that on any other speaker.
This is not critical listening in the classical sense, this is to help ensure when I sit down for listening - I know I have the bugs more or less worked out and I am less prone to wasting a glass (or three) of Scotch and an hour or two listening for shortcomings. Sometimes if I am listening to music I am unfamiliar with, my brain will try to convince my ears I missed something, but I have become pretty good at telling my brain to shut the hell up and enjoy.
I will not be sharing my test tracks, not out of secrecy or anything like that; more because they just are not that interesting. What is important is to use music you are familiar with, and listen to a new design against a reference that you find pleasing.
My current DIY 2ways seem to have what should be a somewhat obvious deviation from what modelling shows where reversing tweeter polarity to the woofer should be more ideal but I literally could not hear a difference in practice even while A/B-ing between them with one wired -+/-+ and the other -+/+-... That includes music and sine waves (sadly I didn't realize the potential of pinknoise at the time).
I'm guessing this is likely because both my woofer and tweeter are simply mounted on-surface rather than flush-mounted or offset forward/rearward. I have more limited experience looking at the effects of this alignment difference in modelling, but accounting for the difference still makes it look like the difference between wiring the tweeter with matching polarity or reverse with the woofer should create a noticeable difference in frequency response (or at least some kind of phasing issue when moving around).
It's bugging me wondering if this is the kind of thing others might hear as obvious while I'm totally oblivious.
In short, I don't want to blindly make any embarrassingly bad mistakes that are within my likely considerable blind-spot while others give my creations a listen and think "eww, what a deaf noobie" despite being more polite externally. So I'd like to narrow my blind spots as fast as possible. Preferably before MWAF.
Also, once again please don't be offended that I'll mark your answers as not-answers even though they are valid and helpful. I'm just assuming that leaving the post marked as "answered" will mean other folks with advice may ignore it.
When you get the phase in the crossover region matched, you will see a deep notch at the crossover frequency when you reverse the tweeter. Somewhat magically, the imaging will suddenly become very clear, as well as subtle musical aspects that you never heard before on your DIY projects.
I second the suggestion to check out the PETT discussion on recommended test tracks, there's some good discussion in there.
I'll make a few comments, none of which are new, of course:
you should listen to a range of music you know and love, and it should be of varying degrees of recording and mixing quality. To trot out my pet peeve, if the Red Hot Chilli Peppers 'Californication' sounds good on a speaker, nothing much else will as the album is soooo compressed, limited and shrill. I wouldn't test speakers with music I don't like. My brain would be saying 'turn it off'!
I use a range of music for testing: classical chamber music, well and poorly recorded rock/pop, jazz and operatic recordings. Probably 20% of our collection consists of old/poorly mixed or bootleg recordings, so it's important to be able to enjoy that music.
Spoken word/comedy is also a good way to test aspects of bass performance. For example, one of our newsreaders is nick-named "three balls" due to his deep and resonant voice and if a speaker has exaggerated or poor bass response he will sound awful.
I don't have measuring equipment, but I'm happy as long as a range of music sounds good. Of the speakers I've built- all other peoples' designs - only two have what you'd call a 'flat response', but they all sound good to me.
Decent accuracy from roughly 500hz-5000hz would be plenty. Is that a reasonable expectation for an old fashion XLR-to-micpre LDC in the $150-$200 range?...if a lack of digital pre or USB mic isn't a dealbreaker already.
Yeah, holy thread resurrection.
One man's tracks and reasoning. They don't need to be stellar recordings if the reason dictates a specific purpose.
I find Harley's videos interesting, and, because he's a musician, producer and speaker designer, he's always worth listening too...
even if his Sibelius speakers don't use any crossovers; I still don't get how that works.
