PWRRYD's Omni/OB/whatever thread
2
  • I am hoping that you try listening to the open baffle part by itself...
  • I have. Those TC9FD's sound really clear and completely awesome OB. They just don't have anything home below about 300 or 400 Hz.
    Billet6thplanet
    Which for mids - works
  • Worked on simulating a crossover at lunch today. I have something that looks like it should be worthy of building a prototype. 2nd order LR slopes on both xo points. Excellent phase tracking. Impedance drops to 3 ohms in one spot arounf 700 Hz but the impedance phase angle throughout is super benign. Don't think any of my amps will have an issue driving these.
    The crossover points kind of surprised me though. W-M is higher than I expected at 650 Hz and M-T is lower at 2.2 kHz. Probably will be ok. These won't be high SPL, ground pounding speakers. If I end up liking how they sound I might build an upgraded pair with bigger/better woofers. There is a lot of padding on both the mids and the tweeters.
    Tom_S6thplanetugly_wooferGeoffMillar
  • Looking at my sim I am throwing away so much mid output with padding resistors. I might try disconnecting the top mid and remeasure everything. Could make for a simpler project and maybe a higher impedance. Fun project for me so far.
    Nicholas_23tajanes
    Long shot idea here> play with the lower mid as a .5 way vs padding both mids ????
  • edited November 2024
    This project looks really cool!
    I'm just curious, but how did you take measurements and design a crossover for an omni-directional speaker?
    Could it be the same as a 'normal' front facing design with the same drivers, but then, 'off axis' measurements would be different for the woofer because it doesn't really have 'axes'?
    As I have only a very basic understanding of crossovers and design, this project got me thinking!
    Thanks, and good luck with this project: perhaps you could have another naming competition here as per the Tre Stemmes?
  • Think about it like this....a woofer in a three way is basically Omni anyways.
    tajanes
    That makes sense, thanks
    What about something like this: very expensive in Oz and the cabinets look a real nightmare to make. Interesting that unlike Visaton's other kits, there's no supplied FR graph. Is that because the response would be impossible to measure?
    https://www.soundlabsgroup.com.au/p/V-5937-Fontanella-Sat.html
  • Two way, where you'd require midrange from the woofer, would take standard off axis measurements.
  • I'd forgo the ^ agony of hexagonal cabinet construction in favor of Sonotube (Concrete pour forms).
    tajanes
  • What fun is that? I'd take it a step further, hexagonal truncated encloser.๐Ÿ˜†
  • Hexagon is not that difficult, just set the angle an rip the boards the same as any other cabinet except there's eight
    6thplanetBilletGeoffMillar
  • Go for it, Mr. Skillz!
    My trying to make cabinets fancy means I make cabinets every 10 years - if I keep them functional I get one set per year out of my efforts and a lot more experimentation done . . .
  • Where do you put the spare 2 boards in a hexagon?
    I'm guessing that's referring to Nicks miscalculation?๐Ÿ˜†
    ...it's early, Nick, we understand.
    Steve_LeeEd_Perkinsugly_woofer
    Oof, I have yet to muster up the gumption to try a standard 90deg miter on a box let alone doing it 8x on one enclosure. Then the glueup I'm envisioning something similar to herding cats.
    You need a baffle and a back, right?
  • Those cabinets look octagonal to me.
    They are actually octagons. I hate typing, so my posts are usually brief and not always completely explained.
    Visaton's kits give you the cabinet layout and cut list, provide the driver details and supply the crossover schematic. I should load the drivers and crossover into Xsim and see what that looks like. I know it will be traced on data and not measurements but will be interested to see the results.
    Apologies, I didn't want to derail the thread
    @PWRRYD any interest in experimenting with side wing/s to get some bottom end back on the tc9?
  • I haven't. I have used these TC9FD's before (a single per side) OB and like them best almost nude, ie as narrow of a baffle as possible. I think the omni GF180-4 can make this work. I'm making a second MTM baffle tonight/tomorrow so I can actually listen to a pair and decide. I have high hopes... but if it doesn't work out it was low dollars lost in wood. That said, if this experiment sounds good/great I might ratchet it up to the next level with bigger and better woofers. Current measurements are a green light. Ears will tell the truth.
    Billet6thplanet
  • Got the second MTM OB built and a promising looking XO sim. Will be tacking parts together tonight and have a first listen sometime this week. Nice having all the XO components and not stuck waiting for a few pieces.
    Steve_LeeGeoffMillar6thplanet
  • Having my first listen now... nothing stands out as "ugly".
    Tom_S6thplanet
  • Surprisingly the bass is way stronger than the single on axis measurement would suggest! Need to make some adjustments to my prototype crossovers.
    6thplanetNicholas_23Tom_SGeoffMillar
  • That said, they image really well and the midrange sounds very natural. I'm not throwing these in the bonfire yet.
    ugly_woofer6thplanetSteve_Leehifisidetajanes
  • OB midrange....๐Ÿ˜
  • USPS tracking says my truncated SIG180's will be delivered today!!! I'll break them in tonight, measure them tomorrow before family gets here for Turkey Day, and may be listening to them on Friday :)
