Insomnia has its advantages...
13»
  • So I ordered a pair of the metal dome ND25, and a pair of the ND28.
    I like the ND25, it is grilled so might match the mid a little better.
  • edited August 2024
    It's response seems similar to the MCM Ti dome if I remember right. Has that HF breakup peak. So nothing you haven't dealt with before.
    Well shoot. I forgot about their automotive oriented stuff. The AN25F-4 is $33/pr and seems to have a very similar response, db and resonance to the DSN25F. Could potentially be a replacement without change to the xo.
    I used the AN25Ti-4 and felt it was a little sizzly, but not bad considering what it was. I didn't use the install frame, wrapped the perimeter with adhesive craft foam, and wedged it into place.
  • I've used the ND25 several of times and prefer it over the ND28. I've also used the Ti version and liked that too.
    Turn2
  • I'm hoping the ND25 is the one for this design. With the grill it is should be a cool cosmetic match.
  • Since I crossed at 5k I think either option might be a drop in. It is far enough from the resonant frequency that it shouldn't effect shit too much.
    If I have time this weekend I'll take some measurements. I have to help direct parking at our work open house on Saturday. Mandatory fun, I guess.
