I will update this when I get the chance, but for now going to keep rolling....
Crossovers are built and fit, mounting holes for woofers pre drilled and back panel fit for gear.  So that meant I finally got to start the finish!!
I sanded everything to 320 and gave it a good wipe down.  Got a thick coat of tung oil down hopefully and will 600 that tomorrow afternoon and then recoat and repeat 3 or 4 or however many more times.
Next time I need to be more careful in the heat working that I don't pool sweat on the material. You can see the discoloration in the wood from where I did. Oh well.....live and learn.
Now, before you all go crazy on me, I know...they are 3" drivers. BUT!! I decided to do some testing.... through the Wondom 2x50 bluetooth the bass is lacking.... so I attempted to utilize the aux in cable.....it barely output any sound at all...Need to contact PE about that.
So then I hooked up my Sure 2x100 through a 3.5mm mini plug.....uhmm....WOW!! What kickass dynamic soundstage mongers!!! EXACTLY what I was hoping for.....TOO BAD I CAN'T FIT THE BOARD!!!!!
So I'm kind of at a crossroads. Say meh, good enough...... or do I try to find a 2x100 board that runs off 19V that is small enough? I don't think it's possible unless I try to find a different battery pack as well......
UGH!
Updated pics to come.....
Let me know if you got any further suggestions. Appreciate the help already given.
