HiVi DM-7500 and DSP . . .
  • This ^ is very interesting to me.
    Thanks for finding and posting this example - it would also be interesting to see how other driver types fare in this regard.
  • edited April 2
    I FINALLY got off my ass and modified the mini towers last night to install the DM7500's.
    after just a few tweaks to the DSP/XO's and standing mid field in the sweet listening triangle these things are nothing short of amazing.
    That airy/breathy ambience that only a dome can bring is now added at lower frequencies making piano and vocals sound much more intimate like actually having them there in the room with me.
    I left them to break-in @300Hz last night and probably move those speakers to my drum room today for mid-field monitors.
    One note - Still need a woofer to reach/play to about 800 ~ 1KHz in order to give the combo depth as the DM7500 lacks the piston-punch of a cone but the SB20PFC's are doing that just fine . . .
  • Added:
    My only complaint with the DM7500 is that the soldering work in attaching the voice coil wires to the spade terminals was a bit thick as I was unable to utilize standard 1/4" Sta-Con crimp connectors and had to solder pigtails to those terminals - not a show stopper.
  • Looks like the MiniDSP 4X10 is TU after trying to get it going tonight - worked for a few minutes then stopped output on the mini towers so I got fed-up with it and pulled it and the amps from service - now choking on dust/ cleaning and reconfiguring the drum recording rack with a newer system - going to try this new Acoustas DSP amp 1st and see how it performs now that I have a Windows UI for it fresh in my hands . . .
  • Hey Eric - that Acoustas DSP amp is a spectacular performing piece of gear for mixing/mastering amp.
    Perfectly quiet with USB and COAX audio input with no discernable distortion even at full volume.
    I'll be purchasing more of them.
  • Looks like a nice piece, but is a bit light on overall power.
  • Not for my needs but for rocking-out it isn't suitable - agreed.
    It's absolutely perfect for my studio as a reference monitoring system - I can't play so loud that I ruin my hearing for the evenings . . .
