Fountek Neo3.5H Ribbon Testing . . .
This ^ thing is so flat, clean and wide with no annoying peaks or dips.
I just got around to clamping it upon the top of my little towers (naked - no baffle) in place of the also awesome HiVi RT1.3 Isodynamic tweets.
It is a drop in replacement that is so smooth and has no peaks anywhere while listening to the same test tracks.
The HiVi unit has a pronounced but delightful response but this Fountek unit just sounds more natural.
Highly recommended.
  • I've got a pair languishing here.
  • JR - These [Neo3.5H] things deserve a mid to XO/accompany them like the SB12MNRX2-25-4 because they are also so flat and clean with no annoying peaks/dips (I have a pair) - SPL-wise, they should blend well.
    I'd love to see what you can come up with as a MT combo using passives, Sir.
    Do you also have those mids in your cache?
  • I do not have those mids, but I have the similar buyouts from PE from a few years ago. I do plan on using them someday as I am really a ribbon guy these days.
    6thplanetSteve_Leerjj45
  • JR, IS it worth your time and effort in creating a passive XO/cabinet design and documenting it for us [currently] DSP-only guys in exchange for a pair of SB12MNRX2-25-4's shipped to your door to keep?
    Maybe Wolf has the time and parts to do this for us, if not you?
    Just asking/testing the waters - this is a good combo, IMO . . . Open to feedback.
  • I used the 3.5h crossed to a HIVI C3N-III, and I have to say that speaker is my favorite I have heard in the mid/highs. It made for a really flat mid to top end. I have also wanted to use the SB12MNRX2-25 and think it would make a great combo.
  • I'll give it some thought - I have a few irons in the fire right so would likely enlist Brad's services to do the cabinets.
  • Steve,
    Can you (1) measure the depth of the waveguide and (2) maybe post several pics at different angles of the tweeter?
    I may design a 3D printed waveguide for the GRS knock-offs.
    Other than JR's favorite one with the round faceplate, the rest have come down another $10 since March 20th.
    Steve_Lee6thplanet
  • If I hadn't just bought a new carb for the truck, I would grab a pair of the little fellers to do a budget banger with.
  • I sold my pair to Don without even trying them :/
    rjj45Steve_Lee
    They join a couple of other pairs of ribbons on my shelf.
    I gotta retire soon, and get serious about building speakers!
  • edited May 2024
    @a4eaudio said:
    Steve,
    David, Yes I'll get you the dimensions and pics and update this post with that data - Here are some screen shots from Madi's site:
  • The Neo3.5H and the HiVi DMB dome are 10.25" apart CTC and sound seamless - sound stage has more depth - I was quite pleased by this serendipity.
    PWRRYD6thplanetjr@mactajanesAnalogkid455
  • edited May 2024
    This is great tweeter.
    And someone already measured it; so you don’t have to.
    Also works great on a baffle
    Note that is has real response up to 40Khz, but without the peaky resonance of hard domes.
    A gem IHMO.
    Steve,
    Have you considered a LR2 4Khz high pass crossover for it? In conjunction with a bit of EQ to flatten response of the DMB-A, add a LR2 4KHz low pass for it, then reverse the polarity…
  • I shall give that ^ a try, Thanh - thanks for the suggestion.
    Steve,
    Just configured the new Control-4 amp and applied your settings as follows on the mini towers (above pic) and it sounds holographic/like actually being on the drum kit in a live session with musicians all around me!
    Note that each stereo driver pair are inverted:
    Incredible!
    I love tinkering and learning new stuff - if I ever had it all figured out I would lose interest quickly . . .
  • Note that each stereo driver pair are inverted:
    Why?
  • Try it and you will understand, Ken - I don't actually know why it sounds so good right now and I am packing to get out of here - I'll get back to this when I can . . .
    Best!
  • edited May 2024
    To be clear, for each speaker. your tweeter should be inverted with the mid, in a LR2 crossover.
    But you’re putting your left speaker out of phase with your right speaker??
    Hmmm.
    I think some physical wiring might be out of phase. Or you’re sitting in a spot where has a null. OR, you just enjoy it a bit more having L/R channels out of phase. It’s a spatial/open sensation that’s hard to describe, and can be surprising at first, but may grow odd over time. Anyway, you can look into it when you get back.
    rjj45Steve_Lee
  • Will do, and thanks.
  • Interesting measurements between on baffle, and sans baffle here:
    https://ampslab-spk.com/2021/02/25/fountek-cd35h/
  • The dip at 1500hz might be the frame of the horn. The dip at 3k seems too high to be baffle diffraction.
  • edited June 2025
    The no baffle option is almost good enough to verify calibration of the upper octaves of a mic.
  • I was wondering if a narrow hardwood frame around it would spoil that great response?
