Iaell - 8" 3-way
13»
  • So how is PT / shoulder doing?
  • Shoulder is pretty good, started lifting weights this week!
    tajanesSteve_LeeEggguyjhollanderkenrhodes
  • start slow
    6-pack, 12-pack, case, before the keggers 😎
    jr@macSteve_Lee
  • Beautiful!
  • I am waiting for the caps to arrive - trying a different brand I can only find on AliExpress.
    See how they go.
    tajanesScottS
  • I'm interested in your thoughts on those caps. Hovland was a pretty good name in film and foils, and known for being pretty revealing.
  • I'll report as well as I can.
  • The old Hovland Musicap manufacturer went under in 2009. Too bad, as I always thought they sounded great in tube gear. But they were a little expensive to use in my own experimental creations.
  • Getting anxious for the caps to show up, want to get this one buttoned up.
    Got the utility room/workbench cleaned up and ready to go.
    I want to get to brainstorming my next project which will likely be a small 2-way.
  • Yep, IMB was the manufacturer. First Hovland MusiCap in yellow, then the black SuperCap version was made, and then a return to the Hovland brand in blue as shown. I couldn't find them elsewhere either, but coulda sworn I say them at PCX at one point. Tony Gee has not tried these, so they must be fairly recent.
    I have some IMB and classic MusiCaps pending for use in my build with the CAT378 and NE180-4.
  • I have a signature.
  • Could be counterfeit, but that doesn't automatically make them bad. Very well may be great caps.
  • edited March 2024
    The price is certainly good. And insulated leads. They look like stranded wire. Haven't seen that other than some Solens I bought from Madisound about 30 years ago.
  • edited March 2024
    The ones I already have are well within tolerance.
    Just your basic MKP capacitor with fancy leads is all
    Possibly counterfeit. I don't care so much about that possibility, just hope the next ones are within spec as well.
  • The older Hovlands were stranded too. Always found that a bit odd myself.
  • Well my first interaction with AliExpress was a pain in the ass, but stuff finally showed up. With as much as you've ordered, I hope it's not always like that.
    The only complaint I have so far, and I do order quite a bit from AliExpress, is shipping can be quite slow - especially for larger items like drivers.
  • Sofar I've had positive results. Just gotta wait for the stuff to circle the globe. One item I think is going via sea instead of air. So not only is it taking quite a while, but it seems the tracking info is extra sparse as well.
  • So I bought a pair of Seas Prestige 6" drivers in 4 ohm. The pair was $150 from Madi. I'm going to use them in my next build, love a good breakup challenge.
    I'll start a separate thread when they get here and I measure T/s.
  • Yeah, +15dB from nominal that breakup is...
  • I'm always impressed by a breakup that also shows up in the impedance plot. "We're not damping anything, good luck." - Seas.
    I used to look at those as possible woofers in the "Matrix Revolution" project - but was happy enough with the ND-140's to stick with them. The revolutions are in a good place right now hanging out with the Classe amp.
    The little alcove provides a variable amount of bass reinforcement depending on how far I place the speakers from the wall. It can deliver the "how are 5" woofers doing that" impression.
    kenrhodesjr@mac
  • Right now I'm pretty damn sick, so even if the caps show up tomorrow I won't be doing anything with them.
  • Tired of waiting for slow boat for the blue caps, so started knocking the crossovers together this morning.
    On left are the woofer/tweeter portions which are complete and on right is the midrange section which has wires yet to attach. I used all Rival Polar Caps on the T/M with the exception of the notch filter on the mid, and a big honking Audiophiler cap on the woofer.
    johnny5jzSteve_Leetajanesugly_wooferTom_S4thtry
  • kenrhodeshifisidejohnny5jzsilverDugly_wooferSteve_Leetajanes6thplanetTom_SColonel7and 1 other.
  • Infinity would be proud. Cool build.
  • edited March 2024
    With full awareness our aural memories are for shit, I do believe I exceeded the Interlude model I used as my inspiration. That being said, I still have a lot of respect for 2000s Infinity line-up. I know one of their designers from that time frame and he is passionate about doing things right and has the usual issue in most commercial speakers - accountants.
  • edited March 2024
    ..also, the bass is tremendous out of this woofer. No subwoofer needed, plenty of slam and good extension. I should have used a larger diameter port - the only wart we have found on this design so far.
  • Yes, there was a time when Infinity wasn't average junk.
    jr@macugly_woofer
