Rival 7" plus XT25 in the visaton WG + recycled Polk cab
2
  • Spaghetti form.
    ScottSjr@machifisidekenrhodesRon_Etajanesjohnny5jzrjj45
  • Stereo-getthi
    So far, I think it works.
    Colonel7ugly_woofertajaneshifisideSteve_Leerjj456thplanetdcibel
  • They look great!
  • So wonderful!
  • Anyone know if that adaptor plate will work on the standard Beastmode tweeter?
  • edited March 2024
    I am using a similar adapter with the XT25 Beastmode and a Viston WG148
    Yeah, that's the one I use. Not too mush trouble to remove the faceplate from the tweeter.
    Pick off all the glue first, then remove the screws.
    It does, measured in previous page.
  • Printed the somasonus 5"
    Here it is without supports
    The Dx25 fits nicely
    It seems like it will drop in place of the visaton 148
    Colonel7Steve_Leerjj45jr@macsilverDjohnny5jz
  • How long did it take to print that WG? How much filament did it use?
  • I'd be interested in a pair of these, curious to see measurements.
    2:47 in the makerspace's Bambu x1 carbon. Weighted 83 gram of PLA+CF.
  • Wow, that's a very fast print for an item that size!
    Yeah, I bet that is 15+ hours each on my Ender 5..
  • Yeah, the bambu is fast.
    a4eaudioSteve_LeesilverD
  • Care to share the 3D file for that waveguide?
    I think I used the 5 no ps from:
    https://www.somasonus.net/scanspeak-d3004-6640
  • Well, the cutout needed for the somasonus is 10mm larger than what I have in the cab...
    That kind of sucks, might measure in different baffle just to see if I want to take the router to my cab again...
  • Why not just modify the Somasonus WG diameter to match the Visaton 148? We know it will print fast.
    That is an option.
    rjj45Steve_Lee
  • That should work. Around the same time it seems.
    Steve_Lee6thplanet
  • xt25 in the somasonus WG
  • I think I'll call it done with the visaton WG:
    tajanesugly_wooferrjj45Steve_Lee
  • That should work.
    jr@macTom_SPWRRYDjohnny5jz6thplanetrjj45tajanes
  • Wrapping inductors with tape...interesting, as I often unwind to get to the desired level but had just used the plastic ties. Thanks, I plan on 'borrowing' the idea for my next Xover.
    Yeah, got JF inductors and unwound them to spec, the air core has zip ties, but a bit of tape prevents my clumsy hands scratching them as well.
  • I usually wrap my coils tight with blue painters tape then add a couple zip ties just so the tape can't ever start to peal back.
  • edited March 2024
    Ok- painters tape vs electrical tape + and - ‘s? Or not really? I’d think electrical with a bit of elasticity might be a plus?
  • Painters tape is designed not to stick. Electrical tape is designed to stay put.
  • Maybe I’ve been doing it wrong all this time. I don’t even take zip ties off. I just push the wire through.
