I am looking for a 2 ohm 6" speaker for my Jeep. It has the Infinity stereo and apparently the drivers are all 2 ohm. I don't want to replace the whole system just the door speakers (they are pooched). I have about 2.75" of mounting depth. Any ideas??
Someday I plan on installing these in my Kia (which also uses 2 ohm nominal drivers):
https://www.amazon.com/JBL-GX600C-2-Way-Component-Loudspeakers/dp/B00U0FRU5S
I will probably upgrade the crossover (it uses pretty shitty parts to be honest). I measured the T/S on the woofers and they are a typical high Q car audio design:
There seems to be plenty of mechanical throw for a shallow design, and surprisingly some under spider venting. About 4-5mm of coil visible above the spider - that is usually a pretty good indicator of Xmax on a non-underhung driver.
Vented back plate, as well. All in all - pretty similar build and feature quality to the Peerless SDS stuff with a lower impedance. Plus, you can buy the entire set at Amazon for $78/pr. which places it squarely in high value territory considering you get a pair of tweeters and (an admittedly shitty) crossover. The SD is somewhat higher than a typical 6.5" due to the usage of Harman's so-called "+1" cone geometry. You could do a lot worse.
FYI: the posted T/S were taken before break-in, I believe Q fell to under 0.8 after I exercised things for a bit.
Here's what I have.Mike
Mike
