Midwest Audio Club drivers.
1246789
  • I reached out to RAD about it. Think I did but not 100% sure if I posted anything about that here.
  • No biggy. The drivers were great and my wife just made me store them in the garage for the first 6 months or so.
  • @PWRRYD said:
    When my quad of R176-CP-08's showed up from RAD and I opened the box I was hit in the face with the worst/strongest cigarette smoke smell. Like someone was in the box smoking. It took years for the smell to fade off the drivers' soft parts.
    I got a four pack of them but never noticed anything. They’ve been in the collection for years now so it’s too late to notice anymore, but I know I wouldn’t have missed that.
  • I can second Craig's observation, cigarette+ new electronics or something like that.
  • Yeah I had noticed that too, I mentioned it and my next few shipments did not smell. All good, the Rival Rush was fun while it lasted. Sorry they couldn't get any traction.
  • hifisideSilver1omotajanesBryan@MAC4thtry
  • edited November 2023
    They look great, and did you pick up some new cables? as you have your amp centered…
    Some DIY cables I made a few years ago. I also bought some appropriate length interconnects.
  • Kinda needs an aluminum dome or ribbon up there. Otherwise, nice units🤘🏼
  • Anyone have any experience with the Newark 53-5165 tweeter? I have a pair and they're a perfect cosmetic match with the MAC drivers.
    Steve_Lee6thplanet
  • edited December 2023
    Spec sheet is awfully thin on details/T&S parameters . . . --> https://www.farnell.com/datasheets/3686239.pdf
  • Well they look great together textures and colors.
    DanP
  • Specs look good if there accurate. Price is nice.
    @PWRRYD - did you ever measure, or even better use, the ones that you used to have (that I now have on my supply shelf)?
  • They have a wonky response, but are super clean above 3K.
    That lowered shelf below 3k should get boosted a little by the narrow 6" baffle it's going on, so that should work well. Probably cross around 2.5 - 3k anyway.
    Wow, forgot where those went. I did measure them, don't remember using them. I bet they would work and sound way better than the Bestons I used with my pair of MAC-04 drivers.
    Yeah, that fills in a bit. I used them on a 7-1/2" baffle. The top end is the wonky bit. Arguable if it matters all that much, though. Nice tweeter.
    I did a teardown on one. Copper cap on pole piece, well designed and damped rear chamber.
    That's inspiring, but I'm realizing my artificially imposed and completely unnecessary restrictions require a smaller faceplate tweeter, so I'm changing gears to the DX20 :)
    jr@macjhollanderScottS
  • The DX20's in my "Manganese" outdoor speakers have now survived their 3rd year outside. They are still going strong.
    Steve_LeeDanP
  • Got a text from my wife yesterday that a "very good" smelling box came in the mail. They were shipped in a dryer sheet box. B) I hope every speaker gets shipped in such a good smelling box as it seemed to take the edge off of me buying more stuff I don't need.
    I will be building a TM along the lines of Dan's tower. This should be a good combo. I hope to do them justice.
    PWRRYDhifisideDanPjr@mac6thplanetSteve_LeejhollanderScottSBryan@MACMartyHand 3 others.
  • Got a little work done today. 😀
    tajanesjr@machifisideSilver1omoSteve_LeesilverD6thplanet4thtry
  • Talked with Brad, Mark and Dan and I have their blessing to offer these cabinets available to the MAC members. If someone was interested in building along or wanted to build a set independently please let me know.
  • Those look really nice Ken!
  • Thanks. Getting the dimensions correct is a lot harder than expected. We know to leave some fudge factor when we build manually. With a CNC you assume that it will hold the dimensions that we program but MDF is not stable enough to hold those dimensions.
    a4eaudioSteve_Leerjj454thtry
    I've been working with an X-Carve CNC lately, and having a lot of trouble getting consistent cuts on different boards.
    Not sure yet whether it's just that machine, or something that I can "tighten up" for the precision I need.
  • I looked into the x carve a number of years ago. I would run as high rpm as possible and take slow cuts since your bit size will be limited. Also make sure that when you cut a square both X and Y are accurate. It's easy to assume they will move the same but I have seen many machines need calibrate on their X and Y.
  • Ken which CNC are you using? Also, what was your lazer machine?
  • Torque steering and cutter speed need to be compensated for in the programming/set-up/calibration, don't they?
    I don't know, just asking as an interested observer.
