According to a statement made by Rory over at the other place, the Esoteric are clearanced out and will no longer be available, He alludes to low sales based on the industry not accepting that a world class driver can come from Dayton Audio.
Pity - it was a good cone away from being an extremely competitive driver. Maybe they will direct some resources into developing the stuff DIY'ers have been asking for from Dayton Audio, now.
Aargh, sorry about the rant but the saturation of weird stuff in combination with the pretty pointless web design has rendered PE pretty well useless to me at this point. Just shopping for a capacitor is painful - I routinely get "website stopped responding" errors when I try sorting things. Not good, PE. Not good.
Nothing wrong with old fashioned web design like Meniscus uses. Loads quick, browser friendly, and they don't give a damn about people using handheld devices instead of real computers.
I guess all of this means "PE, why are you killing off useful and interesting and high performance drivers?"
Besides better power handling capacities, why use such a large voice coil for a mid woofer? Between the large VC, lackluster inductance, and the hard cone, the top end is going to be suck. Then there was the oversized faceplate tweeter that disappeared quickly due to copyright infringement. Whoever designed this line needs to get over Morel and Dynaudio and take notes from SB Acoustics, ScanSpeak, or even Motus instead.
Morel is their favorite brand to rip-off, no idea why.
Jim
I have a pair of Wavecore 4-1/2" midwoofers with the Nomex cone that are on the docket. Can't make up my mind on tweeter choice, but leaning towards the Viawave. It has interesting T/S parameters similar to some other small woofers I have tested that should yield a relatively low F3 while also offering a lot of excursion protection. If the motor is well behaved at higher excursion, it should yield a very nice little monitor.
Jim
Moving to Emotiva was a wise move on his part.
Based on the new curves for the Esoteric drivers, I suspect they applied some damping material around the cone somewhere to tame the midrange gunk. Hope it has a ripple effect on the rising distortion in the midrange.
I read also that they are working on a new Esoteric tweeter. I hope they fix the various serious shortcomings in that bad boy. The chamber is way bigger than it needed to be, and I suspect the faceplate geometry was not well thought out.
