Who's Online (9)
Opamp evaluation board.
I have a really clean headphone amp that is all class A but has no "flavor". Looking to build a preamp that will let me swap opamps at will. There are a plethora of dip 8 opamps and a slew of discreet op amps from recording equipment. Does anyone make a solution to try these without buying a bunch of preamps?
I have found a few that let you swap dip 8 but I haven't found anything for the discreet opamps from recording equipment other than recording equipment, those are a bit spendy for me.
Any suggestions are welcome as I understand I'm looking for an odd solution.
  • Check out Rod Elliot sound project 113, it has an Opamp input and he has suggestions for swapping. It's not exactly what you're looking for, but take a look.
