Very dangerous when you are half asleep late at night after a very stressful day at work and the eBay app on your phone buzzes, auction about to end. Your mind goes into fight mode adrenaline pumping, all dorwsiness disappers, and you are hyper sensitive, you body mind and soul channelling all it's energy into the tip of your fingers and you very tensely concentrate on.... Click... Wait, what, who, where ...
 What did just happen.... The buzzes again, with a congratulatory message, apparently I am the winner of.....
a bit off from each other, but they will be active, so hopefully, should not be too much trouble
Ceramic insert with an aluminum over-wrap. I bought 18 in the 27 ohm value and 16 in the 1 ohm value. I have a problem with buying resistors, I tallied up the last two months and I am about $250 into this buying spree for vintage wire wound resistors. Guess sandcast just lost their appeal. Most of ones I have bought are NOS Dale with a smattering of Soviet and other stuff. The old Dale resistors have what looks like 16awg or better leads, though, worth the price of admission over the the shit tinsel crap on modern sand cast stuff.
Cheaper wire wounds are generally single wrapped, look like this from the side: \\\\
Then there are those who issue the challenge of "prove to me the inductance of a 4 ohm wire wound matters" as it may actually be on the order of 0.001 or 0.002mH.
Me? I just prefer the looks of this type of resistor:
That happens to be a 100ohm Dale, not sure of any other actual details other than when they arrived here they were mounted on a bigass cardboard backer that looked about 40 years old.
No idea the general construction, either. Either enamel or silicone coated.
That is pretty much all I know about them. Oh, and the thermal ratings can be deceiving. For example, the fancy heat-sinked resistors are small form factor for a given wattage - however if they are not mounted to a chunk of heat conductive material to serve as an additional heat sink, their power handling is generally derated quite a bit.
So, no commentary from me on resistors other than some general background on construction methods - I buy on looks.
