I have wanted to design a boombox for some time. I did actually build one with vifa tc9 drivers. But I wasn't thrilled with it. The point of this post is to help me understand comb filtering with to drivers so close together. Walking in front of the last one sounded strange. I assume this was from interaction of the sound waves coming from the drivers being so close together. I wonder if this could be improved by angling the drivers away from each other. Or putting them on the sides of the enclosure. Has this been discussed to death elsewhere?
Thanks!
I really don't have much to offer other than to suggest going with a 2-way design rather than a full range design if possible.
One of my design team projects was going to be a "hifi" portable boom box, but I lost the luster since it will require effort I decided would not be worth the reward.
The other thing with boom boxes is they have a steep build cost. Its pretty inexpensive to slap one together, but to get some real power and fidelity requires bigger amps/batteries etc.
Likely why close enough is good enough.
