I'm playing around with Limp and was wondering when you do the added mass method to determine the T/S parameters you get two results for v/c impedance - Le and L2 - do you add these two numbers together to get the result? The driver i'm measuring says .77mH on the website and I get .227 for Le and .435 for L2.
That being said, no worries. Knowing Le can give an extremely limited idea of how a driver will perform distortion wise, but is otherwise of no interest in this day and age if computer based design tools.
LIMP away.
