I can't stop.
Folks, I need inspiration. I'm feeling compelled to dive back in before Iowa. Hoping you can provide driver suggestions for a passive three-way. Medium to expensive. No metal. Pretty flexible other than those limitations. Coax? Pro drivers? Anything new and hot?
Have at it!
  • The Satori coax was finally released.
    There are the new Dayton MX and GRS HE woofers. Dayton has the new 2x7 woofer.
    More?
  • Wolf beat me to mentioning the Satori coaxial. It's not actually available anywhere yet though, which may rule out something using it for Iowa. https://sbacoustics.com/product/7½-satori-mt19cp-8-paper/
    An idea using a new midrange and some good bargains...Dayton Audio AMT2-4, New HiVi poly cone midrange, 10" SB29NRX75-8 woofers.
    HiVi Poly cone 5" midrange. https://www.parts-express.com/HiVi-D5.4-II-5-Poly-Cone-Neodymium-Woofer-4-Ohms-297-472?quantity=1
    With the two Dayton Audio AMT2-4's left in stock at Meniscus (30% off of $69)
    And the 10" SB29NRX75-8 (One left in stock at Meniscus for $131 (30% off $192), the other on sale at Madisound for $159.
  • edited July 2023
    I second the GRS HE subwoofers. For not much $ they seem to be able to dig deep for very reasonable enclosure space. That'll let you focus those dollars on the rest of the frequency range.
  • The GRS are not woofers, they are true subwoofers - at least the 12" is. The distortion is already audible at 150Hz. Crossed at 60-80hz they are absolute beasts. The 8" might work as an anchor on a 3-way and maybe I'll borrow the pair Nick bought and test it out as a replacement for that 8" 3-way I did with the GRS poly subwoofer, which is absolutely usable as a woofer.
    True I was messing about with the 8" in sims moreso than the others so that is the one I was most thinking of.
  • Thanks for the suggestions. I'm not going to get a build done by IA. Dang. Will probably attend anyway.
    Yah you better come, not like you are driving from AZ these days.
