New project - The Farvalpeas
edited July 2023 in DIY
As I mentioned in another thread I have started a new project using only Peerless drivers. It will be a small MTM, 11 Liters total. The woofers will be the 830855 4" SDS series and the tweeter will be the DA25BG08-06 aluminum domes. The woofers should be here later today. I bought the tweeters from PE when they were on sale for $25. Got started yesterday after work. It took just over one of those 11.5" x 8" x 5/8" Menards particle board shelf boards. These will be ported using some 2" ID CPVC conduit.
rjj45ugly_wooferSteve_Leesquamishdroc
  • Simple box model. Not bad for a pair of 4" woofers.
  • Coolness! I'll have something to directly compare to when I get around to doing mine.
  • Odd. Around here cpvc is yellow'ish and regular sched40/80 white.
  • I don't think you have to worry about PE stealing the name of this one.
    jr@maccharlielaubrjj45Steve_Leeugly_wooferTurn2
  • This is not the CPVC you buy at the big box stores. It's from a national pipe supplier. Generally our CPVC is slightly darker gray than our PVC. We use it due to elevated temperatures (up to ~200 F). This is not the white stuff intended for drains and household water supply. My picture looks a little lighter because I sand blasted them and the cell phone camera flash.
  • The drivers showed up yesterday as expected. Cute little buggers! I broke them in for 5 hours last night. Will measure their T/S parameters after work today.
  • These 4 drivers measured within 1% of each other and within 5% of the manufacturer's published specs. Pretty typical of all my results using Peerless, SB Acoustics, and even Dayton RS series drivers.
  • Can you post the TS parameters you measured please.
    Thanks.
  • Sorry Ken, just now saw your post. I looked but can't find them here at home. Must be at work. I'll post them when I get back.
  • edited July 2023
    Couple of progress pics:
    Fixed pic
    Silver1omo6thplanetDrummer
  • edited July 2023
    Fixed pic
  • Weird... I don't like posting pics directly from my phone. Somehow it edits out the background.
  • Kind of cool if you can figure how it works.
  • @PWRRYD said:
    Weird... I don't like posting pics directly from my phone. Somehow it edits out the backgroundThat sounds like a phone feature you can turn off> @PWRRYD said:
  • Actually kinda neat looking.
    Agreed. While the selection tool is pretty fuzzy on the edges it does a great job of hiding the bloody bodies stacked in the corner, or whatever revealing details may be lurking there.
    Kornbread6thplanetSilver1omo
  • I thought maybe you neglected mowing in favor of building these speakers and just didn't want an overgrown yard to show in the background.
    6thplanetugly_woofer
  • I see background!
  • Almost ready for measurements:
    jhollanderjr@macDrummerhifisidetajanesWolfSilver1omo6thplanetNicholas_23Steve_Leeand 1 other.
  • I've decided to complete the finish on the baffles and the finish on the boxes before I take all the measurements. Usually I throw them together naked just to get my measurements for the xo design and do the voicing. But then I dread having to take them all apart, remove the internal damping, remove the foam gasket tape that seals the baffles to the boxes, etc. This way I might be able to just remove a woofer or two to mount the xo's inside. Postponed gratification maybe?
  • edited July 2023
    lol That is normally how I do it. Or I would just wind up listening and never finish em.
    I think I'll try solid wood baffles on my MTM too (though I'll have to order that in). I ve got a 2ftx4ft sheet of paper backed cherry veneer, but that wouldn't get me enough to do vertical grain on the baffle along with covering the other visible faces.
  • Baffles are done, boxes just need a final sanding then a couple of final color coats:
    ugly_wooferhifiside4thtrytajanesSteve_LeeSilver1omo6thplanetrjj45Turn2S7910
  • edited July 2023
    I really like the sort of "cinnamon" color the BLO/thinner/poly gives these oak baffles. Way better than the classic "Golden Oak" stain/gloss poly look. Thanks Dave Fred for the 1:1:1 tip! These have a satin finish which I prefer for oak.
  • How is the dry time on that 1:1:1?
    With a box fan only about 12 hours.
  • Ready for MWAF...
    Steve_LeePWRRYD
    You can tune the mix, more thinner will dry faster.
    Add more oil and it will dry slower but have a more oily look.
  • Yes of course you are 100% correct. But I really like the simple baseline 1:1:1 ratio. I know everytime exactly what to expect (call me a non-adventurous person lol). If I end up wanting a bit more sheen then I will just give them a coat of furnature wax =)
