8 Ohm Compatible Multi-Channel Amps and DSP . . .
Looking at this compact multi-channel amp [the manual] says this concerning speaker load impedance -->
"Speaker Connections - Each channel of the Z•660 is rated to handle a minimum 8 ohm load. Amplifier loads below 8 ohms can switch the output devices into "limit" at high dynamic music peaks, causing distortion and/or damage to the amplifier"
Data source = https://www.manualslib.com/manual/808037/Elan-Z-660.html?page=6#manual
My question to you knowledgeable guys is --> If the ^ amp is used to power individual drivers of lower impedance [3 ~ 6 Ohm] (W, M, T) at low SPL levels of less than 90 DB, would the amp be suitable for a multi-channel DSP application regardless of the 8 Ohm minimum admonishment?
In my mind, the woofer is the real issue as it requires the most current/voltage to function while the the mid and tweeter are not going to stress the unit very much if at all.
Thanks for any useful feedback.
