Here we go again with PE just peddling sub-par stuff. I know I am not suppose to say these things since I am in the "design team" this year, but everything I get from them lately is garbage.
Latest is their 4% silver solder. I have been using the PE 4% for literally DECADES. I just opened a new roll last build and noticed it was hard to work with.
I then noticed it was EATING my solder tips because the flux is so agressive.
It destroyed the tip on my radio shack gun that has been on there for nearly 5 years, and just ate through 3 effing tips on my 60W iron while soldering the ACG crossovers.
What do you guys use, preferably silver bering, that you would recommend?
Should also notify PE, could be a bad batch or defective product and if I was them I'd want to know.
Thanks!
Javad
Jim
This is not a flux, or core thing....Its chemestey. Better quality solder contains a small amount of copper to prevent this, or slow this from happening.
Apparently this happens with tin/lead solder, though a eutectic mix like 63/37 slows the process.
Better quality solder tips have a deposited layer of iron which slows this whole tip-becoming-one -with-the-solder thing.
So, it seems the better quality tip build of the older radio shack irons and gun I used combined with the old style silver bering solder from PE that has a 0.4% copper content made for years of sailing down easy street.
Looks like I will grab some Monday from MCM with more drivers I don't need!
"I prefer the standard ROHS (Reduction of Hazardous Substances) solder to silver solder. Silver solder generally has a melting point that is too high.
Four things are important in solder:
Good flux
Good wetting
Narrow or zero eutectic range (does it melt and solidify at a single temperature rather than become a 'putty' for a range)?
Melting point - should be about the same temp as standard tin-lead.
It is hard to judge a particular alloy or flux without trying it. But one thing for certain, Kester knows more about solder than anyone else. I don't know where they buy it, but here is a source.
https://tinyurl.com/jutqvd3
I would pay more for the good stuff, since a $25 roll of bad solder is nearly useless.
And as you probably know, solder that has 4% silver is not much more conductive than tin-lead (maybe less so because of the other alloying components).
And of course, there is no difference in the signal going through.
No one in the electronics industry uses silver solder. It isn't because of the cost. A lot of what we do at Dawn is nearly "cost is no object" stuff. When we make
a $6,000 circuit board, the cost of solder is of no consequence. It is true that silver solder is physically stronger than tin-lead or other alloys, but if you are using solder as the only means of attachment, you aren't doing it right. Buy the Kester.
I use silver solder for repairing jewelry - only."
I bought what he recommended (Kester K100LD) and haven't had any problems with it.
That being said, I've learned a little bit from this thread and I'll actually look at what I'm buying next time. Thanks guys.
Here's a link to Amazon for Kester 44 63/37 solder that is rosin core.
https://www.amazon.com/s/ref=nb_sb_ss_i_4_6?url=search-alias%3Daps&field-keywords=kester+44+rosin+core+solder+63+37&sprefix=Kester%2Caps%2C181&crid=2FHA6CBMBAJDM
It has a melting temp of 361F so it melts easily and flows well. Like I said, no worries of cold soldering joints or damage using this solder with a good soldering station.HTH
Jim
Here is an example of one you can buy, but a largish computer fan and some wood with hardboard wings, or even that posterboard/foamboard stuff used for projects is just fine too.
http://www.newark.com/ok-industries/sa-91/fume-extractor/dp/95F3919?mckv=IP8F68ux&gross_price=true&CATCI=pla-164503916661&CAAGID=20389674261&CMP=KNC-GUSA-GEN-SHOPPING-95F3919&CAGPSPN=pla&gclid=Cj0KEQjwzpfHBRC1iIaL78Ol-eIBEiQAdZPVKred4hNXhSu0W9YmiqcZQoH8D_wtl4mk5Mq28KHe5YgaAkix8P8HAQ&DM_PersistentCookieCreated=true&CAWELAID=120185550001512687
Solder for electronics has flux in the center. That's where terms like "rosin core" comes from so you don't need to add flux if that's what you mean. I use a stand mounted fan to blow the smoke away from me. This is the safety data sheet for Kester 331 flux used in the K100LD solder I bought.
In the past, I have burned up a lot of tips because I would leave the soldering pencil (40W) plugged in all the time and it would get the tip too hot. My 25W pencil did not burn up tips, but it often did not give me the kind of heat that I needed. But since I switched over the the PE Stahl temperature controlled station, I can save tips by boosting the heat to whatever I need for good flow, then back the heat off in between soldering operations.
