Winter plans
12346»
  • I found some black #4 screws online and they fit without drilling. I got to listen to them today and I'm a little disappointed with the low end. Measurements show the port tuning is a little low so hopefully I can improve that.
  • But are they...
    Image result for but is it gmo-free
    kennykNicholas_23jr@macsquamishdroc
  • Well, for some reason pictures I take horizontally with my iPhone like to get stupid when imported to a real computer, but you get the idea.
    Either that, or this software does not respect my authoritay - since it has been rotated and saved and shows as such in Windows Explorer etc.
    Oh well. Price we pay for pretending phones are a reasonable substitute for real cameras I guess.
    kennyksquamishdroc
  • I think your phone is fine.
  • Where do you source your Audyn caps - I am liking the red! And what resistors are those?
  • ani_101 said:
    Where do you source your Audyn caps?
    PE
    *disregard*
    Apparently, if you accidentally click inside of the gray zone indicating quoting - you are not allowed to click anywhere else again. Strange bug.
    As Craig noted, I buy the caps at PE. Most of them are cheaper than the Bennic/Dayton option, and are better looking. I'll leave the sonic signature commentary to those who enjoy that kind of discussion.
    The resistors I purchased on fleabay - I have not seen them for awhile now. They ended up about $1/apiece and I had originally purchased four or five values.
  • Test
    So I just tried duplicating the bug with this post to no avail. Never mind, it is early.
  • I too like the Audyn Q4 (red caps) better than the Dayton, Solen, or Bennics I've used.  They have larger diameter leads, a 400 VDC rating (compared to Dayton's 250 VDC), and are cheaper.  I've measured dozens of them and have never found one to be outside 1% tolerance.
  • JR
    How did you fasten the iron core inductors down?  I just built a crossover with the new Dayton inductors and missed the screw holes for mounting and longer leads that other coils have.  The price was certainly an improvement.
  • That was a preliminary layout. Will probably overdrill holes and use zip ties.
  • I built my crossover on 1/4 Baltic birch and stapled a zip tie in place on each end of the inductor. I put some hot melt glue in a few spots to keep things from wiggling around. It works bu it's not as tidy as the versions that have screw holes.
